Calculating Diaphragm Plates Needed to Stop 30,000 lb Object
  • Thread starter Thread starter brambilah
    Plates
The discussion revolves around calculating the number of 1" welded diaphragm plates needed to stop a 30,000 lb object falling from a height of 90 ft. The potential energy and kinetic energy calculations yield a value of 3.24x10^4 kip*in, with an impact velocity of 76.101 ft/s. Initial calculations suggest that approximately 130 plates may be required, but this figure is questioned by participants who argue that the actual number is likely to be much lower, possibly 2 or 3 plates. Concerns are raised regarding the geometry of the setup and the need to consider the deformation of the plates and welds. Overall, the feasibility of the calculations and the assumptions made are debated, emphasizing the importance of practical applications in similar scenarios.
brambilah
I Have an object with a mass of 30,000 lb falling at a height of 90ft. The object is to be stopped by a series of diaphragms spaced out 6" apart. I am using 1" welded plates as diaphrams. I need to find out how many plates it takes to stop the object. I have calculated my potential energy=kinetic energy to be 3.24x10^4 kip*in and the velocity at impact to be 76.101 ft*s^-1. Also each plate to have a weld capacity of 334 kip. I want to find out how many plates will the object shear before it stops.
Holy smokes! Is this for an episode of MythBusters or something? :bugeye:
Holy smokes! :bugeye:
It's' "only" a 13 ton truck doing 50 mph. That's not a ridiculous thing to contain with a few inches of mild steel.
But without knowing some more about the geometry of the situation, it's impossible to answer the question.
What type of geometry do you need to know??
I used the conservation of momentum. I have initial momentum of ρi=M*a=70.959 kip*sec
*Vi=51.88mph
*Vf=0 mph
*m1=30,000 lb ======>mass of object
*m2=163 lb ======> mass of 2'x2' 1" plate
*t=1" =====>Thickness of diaphragm plate
*Δt= t/((Vi-Vf)/2) =====>Duration of Average impulse
*Δt= 2.19 x 10^-3 sec
*F=250 kip =====>Magnitude of Impulse(Chosen as a practical max.)
*ρ1=ρi-F*Δt =====>Momentum after first impact
*ρ1=70.411 kip*sec
*Δρ1= ρi-ρ1 ======>Change in momentum after first impact
*ρ1=0.548 kip*sec
*V1=ρ1/(m1+m2) ======>Velocity after first impact
*V1=75.105 ft*s^-1
*ΔV1=Vi-V1 ======>Reduction in velocity
*ΔV1=0.996 ft*s^-1
N=ρi/Δp1 =======>Plates required
N=129.6
Can someone verify that these calculations are feasible?
Go and look at some roadside crash barriers, then decide if "130" is a believable answer.
I would calculate how much of work you can do deforming one plate, before you either break the welds, or break the plate due to plastic deformation. Your projectile velocity is low so I don't think you need to worry about punching a "bullet hole" through the plate, or any other dynamic effects.
I would guess the answer is more than one plate (simply from the way the question is asked) but more llkely to be 2 or 3 plates, not 130.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
