Max Value of f(x): 3cos(4πx-1.3) + 5cos(2πx+0.5)
  • Thread starter Thread starter AlbertEinstein
    Max Value
The discussion centers on finding the maximum value of the function f(x) = 3cos(4πx-1.3) + 5cos(2πx+0.5). Participants suggest differentiating the function and setting the derivative to zero, but note that this approach can lead to complex equations. The derivative is given as f’(x) = -[12πsin(4πx-1.3) + 10πsin(2πx+0.5)], which complicates the solution process. To simplify, using the sine addition formula and double angle formulas is recommended, ultimately leading to an equation involving A sin(2πx) + B cos(2πx) = 0. The maximum value of the function is determined to be approximately 5.7811.
AlbertEinstein
The question is find the maximum value of the following function
f(x) = 3cos(4*pi*x-1.3) + 5cos(2*pi*x+0.5).
Mathematics news on Phys.org
"The question"? Where, in your homework?
Looks pretty straight forward to me: differentiate and set the derivative equal to 0. Use the sin(a+b) formula to isolate sin(3\pi x) and cos(3\pi x).
Calculus isn't always helpful!
Hey HallsofIvy,
Your suggestion was quite correct. However I dare say differentiating and equating to zero does not always help.
Here f (x) = 3cos (4*pi*x-1.3) + 5cos (2*pi*x+0.5)
Or, f’ (x) = - [12*pi*sin (4*pi*x-1.3) + 10*pi*sin (2*pi*x+0.5)]
Equating this to zero,
12*pi*sin (4*pi*x-1.3) + 10*pi*sin (2*pi*x+0.5)] = 0
Now if I use the sin (a+b) formula the equation gets rather complicated.
I shall be thankful to you if you could please show the full solution.
However the answer is 5.7811.
Yes, it gets complicated. Anything wrong with that? You'll also, by the way, need to use the double angle formulas to reduce 4\pi x to 2\pi x. After you done all that, you will have an equation of the form A sin(2\pi x)+ B cos(2\pi x)= 0 with rather complicated numbers for A and B. But they are only numbers! Write tan(2\pi x)= -B/A and solve.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
