jdstokes
- 520
- 1
For a system of N non-interacting bosons we start with the tensor product of single particle states \otimes_{n=1}^N | \alpha_i \rangle and then, due to the indistinguisability of the particles, symmetrize to obtain the occupation number state
| n_1,n_2,\ldots,n_k\rangle = \frac{1}{\sqrt{N! n_1!\cdots n_k!}} \sum_{\Pi\in S_N} \otimes_{i=1}^N | \alpha_{\Pi(i)} \rangle
where n_1,\ldots,n_k denote the multiplicities of each single-particle state in the system and S_N denotes the N! permutations of {1,...,N}.
So far so good. In order to describe variable numbers of particles we introduct creation and annihilation operators \hat{a}_\lambda^\dag,\hat{a}_\lambda such that
\hat{a}^\dag_\lambda | n_1,n_2,\ldots,n_k\rangle \propto| n_1,n_2,\ldots, n_\lambda+1 ,\ldots,n_k\rangle, \hat{a}_\lambda | n_1,n_2,\ldots,n_k\rangle \propto| n_1,n_2,\ldots, n_\lambda-1 ,\ldots,n_k\rangle
with as yet to be determined proportionality constants.
I'm trying to figure out what is the minimum information needed to determine the proportionality constants (\sqrt{n_\lambda +1},\sqrt{n_\lambda} respectively.)
Clearly | n_1,n_2,\ldots,n_k\rangle is an eigenstate of a^\dag_\lambda a_\lambda. Suppose now that the a_\lambda,a^\dag_\lambda were constructed such that the corresponding eigenvalue is n_\lambda.
Then by further assuming that the operators obey some commutation relations we can determine the proportionality constants in the first two relations.
Can somebody correct if I am mistaken:
In order to determine the action of a^\dag_\lambda and a_\lambda on occupation number states we must assume the following defining relations:
a^\dag_\lambda a_\lambda | n_1,n_2,\ldots,n_k\rangle = n_\lambda | n_1,n_2,\ldots,n_k\rangle
[a_\lambda a_{\lambda'}^\dag ] = \delta_{\lambda\lambda'}
Is there any simpler way of looking at this?
1)
1)
