The XRD pattern of Zinc oxide and zinc oxide in acrylic acid
  • Thread starter Thread starter justinlee
    Acid Xrd Zinc
The XRD analysis of pure zinc oxide shows distinct peaks at 31.7, 34.4, 36.2, 47.5, 56.6, 62.9, and 67.9 (2-theta degrees). In contrast, zinc oxide dispersed in acrylic acid/IPA exhibits unexpected peaks at 21.6, 27.2, 32.7, 38.4, 44.1, 50.0, 62.1, and 68.5 (2-theta degrees), suggesting potential changes in crystallinity. Concerns were raised about the polymerization of acrylic acid, which could lead to the formation of poly-acrylic acid and additional peaks. The purity of the acrylic acid/IPA mixture and the possibility of forming a zinc soap during polymerization were also discussed. Overall, the discrepancies in the XRD patterns indicate that the medium significantly affects the zinc oxide's crystalline structure.
justinlee
the XRD pattern of Zinc oxide and zinc oxide in acrylic acid !
I did XRD analysis of zinc oxide, and its peaks are at 31.7, 34.4, 36.2, 47.5, 56.6, 62.9 and 67.9 (2-theta degree).
further, I did XRD of zinc oxide dispersed in acrylic acid/IPA. but it's weird ! Why I could got some peaks at 21.6, 27.2, 32.7, 38.4, 44.1, 50.0, 62.1 and 68.5 (2-theta degree), but these peaks are totally different from the peaks of pure zinc oxide ??!
Is it cause of the crystalline has been changed or destroyed ?
thanks for your teaching !
Likes Jarvis Wheeler
Two big concerns with the medium:
1. Acrylic acid polymerizes pretty easily upon radiation. I would hardly be surprised if you've now got significant amounts of poly-acrylic acid in the medium, which may be producing the extra peaks.
2. What are the purity levels of AA/IPA?
I dispersed ZnO particles in AA/IPA mixture which is 50:50 ratio.
And, I add 0.1g ZnO into 1g AA and 5g IPA, then did polymerization; but i could get the apparent peaks of ZnO particles in XRD analysis (there is no any peak )! that's weird !
Could you have formed an acrylic/zinc soap? When you polymerized the AA did you form a gel or did a solid ppt? If you are isolating a ppt, perhaps the zinc component remains in the IPA?
