Earth`s magnetic field and permanent magnets
Earth's magnetic field is relatively weak compared to the magnetic forces of permanent magnets, which is why it does not significantly affect them. The close proximity of the north and south poles of a lodestone results in balanced forces that prevent noticeable movement. While compasses made of lodestone and iron function similarly, the Earth's magnetic field does not cause them to fly through the air. At the poles, the expected attraction of a magnet to the ground is not commonly reported. Overall, the interaction between Earth's magnetic field and permanent magnets is subtle and often overlooked.
Tominator
I was always fascinated by magnets and I never understood, why Earth`s magnetic field doesn`t conspicuously affect permanent magnets. Is it too weak or what?
A compass with a needle made of lodestone should work just as well as one with a needle made of iron. But if by ''conspicuous" you mean flying through the air, then notice that the north and south poles of a piece of lodestone are so close together compared to the scale of the Earth that there is just as much pull towards the north pole as there is a push.
But what if you were on the pole? The magnet should attract to the ground but I have not heard about such a case.
