How to solve for x when it's in exponent?
  • Thread starter Thread starter sarah2529
    Exponent
The discussion revolves around solving for x when it appears in an exponent, particularly in the context of a confusing equation found online. Participants clarify that to isolate x, one should take logarithms of both sides, which can be done in any base, although base 264 simplifies the process. There is confusion regarding the interpretation of the equation, with suggestions that the original poster may not have accurately represented the mathematical expression. An example is provided to illustrate the logarithmic approach, demonstrating how to manipulate the equation to solve for x. Overall, the key takeaway is the importance of correctly isolating the x-term and applying logarithmic properties to solve the equation.
sarah2529
I'm just wondering because I found this crazy picture somewhere on the net.
http://photos-h.ak.fbcdn.net/hphotos-ak-snc3/hs071.snc3/13845_1261921983558_1094945438_30798960_833983_n.jpg
Mathematics news on Phys.org
Log based 264
I see no "x in the exponent" here. Or is that "264^15/99xyz" supposed to be "264^(15/99xyz)" rather than "(264^15)/(99xyz)"?
What about the "*(2n+1)- (pi+ phi)"? Is that in the exponent or not? Looks like the person who posted that on the internet didn't really know what he was doing.
If everything is in the exponent then, like fatra2 said, take logarithms of both sides. If not, subtract the part that is not in the exponent from both sides and then take the logarithm.
You don't NEED to take logarithms base 264 (although that gives the simplest result). Logarithms to any base will do.
It probably isn't at all difficult to solve for x, with the exponent interpreted in any way
I'd say your problem is finding the log base 264 button on that cash machine.
Haha I would need more than 30 secs just to press all the buttons needed to solve for x, let alone figuring out the answer and what the question actually is - from what it says, I would interpret it as
y=\frac{264^{15}.2xyzn}{99}+1-(\pi+\phi)
But it could obviously mean many other forms. And like hallsofivy has said, the person is obviously clueless about this kind of stuff and was leaning much towards the humour of this picture rather than the accuracy of its question.
To answer the basic question, "How to solve for x when it's in the exponent?":
You would need to isolate the x-term on one side of the equation, take the logarithm of both sides of the equation (any base, as long as they're the same), move x from exponent of a logarithm to coefficient of a logarithm (\log{3^X} = X \log 3)[/tex]<br /> <br /> Example:<br /> <br /> 6561 = 3^X[/tex]&lt;br /&gt; \ln{6561} = \ln{3^X}[/tex]&amp;lt;br /&amp;gt; \ln{6561} = X\ln3[/tex]&amp;amp;lt;br /&amp;amp;gt; X = \frac{\ln6561}{\ln3}[/tex]&amp;amp;amp;lt;br /&amp;amp;amp;gt; X = 8[/tex]&amp;amp;amp;amp;lt;br /&amp;amp;amp;amp;gt; \therefore 6561 = 3^8[/tex]
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
