Trying to make a Superconducting tube
TimDubya
I'm doing an experiment which requires the fabrication of a superconducting hollow cylinder but I am unable to find a firm which does custom manufacturing of this nature. I have found numerous which sell the high Tc powders (YBCO BSCCO). My question is if I do just buy the powders what could I do to form my cylinder? I was thinking I could either press it into shape or add a binder of some sort. However I recognize the binder idea may diminish some properties of the HTS.
Any and all insight appreciated.
Can't you just buy a solid cylinder of niobium or aluminum and then drill a hole?
Zz.
Zz.
Liquid helium is expensive.
Yes, but so is making a tube of YBCO that manages to superconduct. I was going to recommend a niobium tube. You can buy these commercially.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
23K
