Hello DaleSpam,
First you had came up with this equation
DaleSpam said:
[tex]r'_d=\left(<br />
t'=\begin{cases}<br />
1.25 \tau - 0.75 d & \mbox{if } \tau \lt 0 \\<br />
\tau - 0.75 d & \mbox{if } \tau \ge 0 <br />
\end{cases},<br />
x'=\begin{cases}<br />
1.25 d - 0.75 \tau & \mbox{if } \tau \lt 0 \\<br />
1.25 d & \mbox{if } \tau \ge 0 <br />
\end{cases}<br />
,0,0\right)[/tex]
Then, I had created the doubt
mananvpanchal said:
We can see that [itex]t'=\tau - 0.75 d, \mbox{if } \tau \ge 0[/itex]. And we know that d=-1 for A, d=0 for O and d=1 for B then, we can get this
[itex]t'_a=\tau + 0.75,[/itex]
[itex]t'_o=\tau,[/itex]
[itex]t'_b=\tau - 0.75[/itex]
But suppose, train is going to opposite direction, then the equation cannot distinguish both [itex]t'[/itex]
And you had solved this by
DaleSpam said:
So, I had to get [itex]t'_a[/itex], [itex]t'_o[/itex], [itex]t'_b[/itex] using [itex]\tau[/itex] and [itex]d[/itex].
After this I had created another doubt
mananvpanchal said:
Yes, you are right. We will get the answer as you said.
There is another doubt!
This may be the case again of generalization.
As [itex]\tau[/itex] increases, desynchronization between two clocks decreases.
And you had came up with the idea of [itex]\tau_a[/itex], [itex]\tau_o[/itex], [itex]\tau_b[/itex]
DaleSpam said:
This is an incorrect reading of the expression. The desynchronization between two clocks remains constant as the [itex]\tau_d[/itex] increase (for [itex]\tau_d>0[/itex]).
For example, consider the clocks [itex]d=0[/itex] and [itex]d=1[/itex]. At t'=100 we have [itex]\tau_0=100[/itex] and [itex]\tau_1=100.75[/itex] so the desynchronization is [itex]\tau_1 - \tau_0=0.75[/itex]. At t'=200 we have [itex]\tau_0=200[/itex] and [itex]\tau_1=200.75[/itex] so the desynchronization is [itex]\tau_1 - \tau_0=0.75[/itex].
So, I had to get [itex]t'_a[/itex], [itex]t'_o[/itex], [itex]t'_b[/itex] using [itex]\tau[/itex] and [itex]d[/itex]. But you had came up with [itex]\tau_a[/itex], [itex]\tau_o[/itex], [itex]\tau_b[/itex].
When, I had asked you
mananvpanchal said:
As we got [itex]\tau = 0.8t[/itex].
Can you please explain me how can I get [itex]\tau_a[/itex] and [itex]\tau_b[/itex]?
You had came up with the idea
DaleSpam said:
So for [itex]\tau_d \ge 0[/itex] we get [itex]\tau_d=0.8t[/itex] in the unprimed frame and we get [itex]\tau_d=t'+0.75d[/itex] in the primed frame.
Then, I had told you
mananvpanchal said:
Now, we have two unknown variables [itex]t'[/itex] and [itex]\tau_d[/itex].
So, now the problem is we have to derive
[itex]t'_b=\tau - 0.75[/itex] using [itex]\tau[/itex], and [itex]d[/itex].
We know here [itex]d_a=-1[/itex], [itex]d_o=0[/itex], [itex]d_b=1[/itex] and [itex]\tau = 0.6t[/itex].
But, To solve "decreasing desync as [itex]\tau[/itex] increases" problem you came up with the idea of [itex]\tau_a[/itex], [itex]\tau_o[/itex], [itex]\tau_b[/itex].
Now, we have the equations.
[itex]t'_a=\tau_a - 0.75 d_a,[/itex]
[itex]t'_o=\tau_o - 0.75 d_o,[/itex]
[itex]t'_b=\tau_b - 0.75 d_b[/itex].
And as I said before we have now two unknown variables per eqaution ([itex]t'_a[/itex], [itex]\tau_a[/itex]), ([itex]t'_o[/itex], [itex]\tau_o[/itex]) and ([itex]t'_b[/itex], [itex]\tau_b[/itex]).
So, the question is how can we get values of [itex]t'_a[/itex], [itex]\tau_a[/itex], [itex]t'_o[/itex], [itex]\tau_o[/itex], [itex]t'_b[/itex] and [itex]\tau_b[/itex] using known variables [itex]t[/itex], [itex]d_a[/itex], [itex]d_o[/itex] and [itex]d_b[/itex]?
