How to Select a Simple Random Sample of Employees Using a List of Numbers?
  • Thread starter Thread starter Larrytsai
    Random
To select a simple random sample of employees using a list of random digits, each number corresponds to a normalized value that can be used to determine an index for the employee list. The process involves dividing the random number by 10000, multiplying by the total number of employees, and applying the floor function to find the corresponding index. For example, the number 11920 yields an index of 2, which corresponds to the employee Becker. The final selected sample from the employee list is Zhao, Becker, and Kim. Understanding this method allows for effective random sampling in small groups.
Larrytsai
David C. White owns a small advertising business. He has twelve employees. The names
of the employees are given below.
1. Becker
2. Brown
3. Chasten
4. Ito
5. Kim
6. Spitzer
7. Taylor
8. Walt
9. Wang
10. Zhang
11. Zhao
12. Zhu
Use the list of random digits below to select a simple random sample of three names from
the list of employees. Start at the beginning of the list and use the numerical labels
attached to the names.
11920 14931 20051 27498 12009 45287 71753 31137 20495 05907
the answer is Zhao, Becker, Kim
I don't know where to start, I do not understand what the list of numbers represent? Anyone mind guiding me through this problem?
Thanks
1. Becker
2. Brown
3. Chasten
4. Ito
5. Kim
6. Spitzer
7. Taylor
8. Walt
9. Wang
10. Zhang
11. Zhao
12. Zhu
Thanks
Hey Larrytsai.
If your table values are between 00000 and 99999 then each value represents a random number between those values. In terms of a uniform distribution your first number would correspond to 11920/10000 = 0.1192.
Now if you want to choose a data entry you have multiply this normalized number by the number of entries you can select from. Then you floor the answer and add one to get the index of the entry. For this example 0.1192 x 12 = 1.4304 so our index is Floor(1.4304) + 1 = 2 which corresponds to the 2nd name.
All this is doing is you get a distribution that approximates a uniform distribution and then you have to make sure your random number is between 0 and 1 and then you basically allocate each block of your distribution to an index. For example for 10 data items (0-0.999999 etc) is allocated to data 1, (0.1,0.1999999etc) allocated to data 2 and so on. and this is why we use the floor function.
thank you so much!
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
