Forces acting on an object -free body diagrams
In dynamics, when a hand exerts a force on a box, an equal and opposite reaction force acts on the hand due to Newton's third law. If a hand pushes a box with 10N, it experiences a 10N reaction force, but the net force on the hand remains zero if it is also supported by the ground. In a scenario without external support, such as in space, both the box and the hand will accelerate away from each other due to the forces acting on them. The net forces depend on the interaction between the objects and external constraints, like friction or support from the ground. Understanding these principles helps clarify the relationship between forces and accelerations in different contexts.
sgstudent
Hi guys, I have a dyanamics question to ask. Thanks for the help!
In the scenario there is two objects-one the box and the hand pushing it
When i push an object, there will be a force acting on the object and hence a reaction force acting on my hand. So, if i were to apply 10N of force on a box i would also receive 10N of force acting on my hand. With just this 2 pieces of information in mind, would it be possible to tell what is the force acted on my hand (FBD of hand) to counteract the 10N reaction force?
Or will the minimum force exerted by my hand equal to the force that i exert on the box meaning 10N of force such that they counteract each other so net force of hand is 0N - or will the force i exert on my hand be 20N such that the net forces of both objects must be equal (if 20N of force exerted on hand net force=20N-10N=10N and on the box, net force=10N of force exerted on the box)? So, is there a rule to follow, like will the two bodies have the same net force, or same acceleration or is it up to me to exert the force on my hand to counteract the box just that i must have a force that is equal to the force exerted on the object itself (or else i will have an opposite net force which probably doesn't work).
I'm unsure about this as there are two bodies to consider and I don't know how to determine the forces of the two object. Thanks for the help! :smile:
If you were in floating in space, and you pushed a box with 10N, it pushes back on you with 10N, and you both fly off in opposite directions, accelerating under this force pair. There are no other forces. What you probably have in mind is standing on the ground pushing on a box. In that case (unless you are standing on ice), you push with 10N on the box and the box pushes back with 10N on you, but you don't accelerate because the ground is in the way. More exactly, your foot pushes the ground with 10N and the ground pushes on you with 10N. The Earth experiences a net 10N, but it is so massive that its acceleration is to small that it is essentially zero. You experience a net 0N, 10 from the box in one direction and 10 from the ground in the opposite direction, so that your acceleration is zero. The box experiences a net 10N and accelerates away from you (assuming the friction between box and ground in negligible).
Forces describe the interaction between two objects. For mechanical forces, these exist at the point of contact. On the other hand, accelerations describe the objects themselves. Newton's law is more clearly written as Ftotal on a body = mbody abody.
Oh the the net forces on the hand will be up to the setter? Like how much force I exert to counteract it or not counteract it at all like in the space example you gave? Thanks for the help!
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
