Need to know what the K stands for in this equation
  • Thread starter Thread starter LocalStudent
The discussion clarifies that in the equation for Root Mean Squared speed, the constant 'k' refers to the Boltzmann constant (1.4e-23). Participants confirm that the equation is applicable for calculating the RMS speed of a molecular gas at a temperature T with molecular mass m. It emphasizes the importance of using the absolute temperature scale in Kelvin and ensuring mass is in kilograms. Additionally, there is a suggestion to check the calculator's input for proper parentheses around the radicands. The conversation indicates that the user will share the specific question later for further assistance.
LocalStudent
I'm busy solving a physics question and I am getting unexpected results.
I just want to check if I am using the right constant in this equation:
I am using the equation to find the Root Mean Squared speed = √(8/3∏) √3kT/m
Is k in this equation the boltzman constant? (1.4e-23)
Yes it is. (As long as you are indeed talking about the RMS speed of a molecular gas or some such at temperature T with molecular mass m)
Thanks. Then I must be going wrong somewhere else.. I'm sure I'll find it. Thanks again
T is in Kelvin, is that the temperature scale you have used?
Make sure your temperature is in absolute scale (e.g. Kelvin), not degrees.
I've used kelvin. And mass in kilograms.
Thanks for the input. I'll post the actual question later and you could see if I've done it correctly or not.
Have you been careful and told your calculator what the correct radicands are? That is, have you used parantheses around the full expression that should stand under the square root signs?
