Water not flow out of capillary
Water does not flow out of a capillary tube when closed at the top due to surface tension and the balance of forces acting on the liquid column. When a finger is placed over the top, it creates a vacuum that prevents air pressure from equalizing, allowing atmospheric pressure to hold the liquid in place. In thin, hydrophilic capillaries, water remains inside even without a finger, while thicker or hydrophobic walls may not retain water as effectively. The same principles apply to a pipette, where ambient pressure keeps the liquid contained. Overall, surface tension and pressure dynamics are key factors in this phenomenon.
kapital
Why does water, in a small glass tube,open at both sides(for example) not flow out if we put it in vertical position and put our finger on the top?(we close it)?
Surface tension. The force binding the surface molecules is greater than the weight of the thin coumn of liquid.
Ok, but why does than have our finger on the top any influence on that?
And why does water not flow out of the pipette, is there the same reason?
Are you thinking more of a drinking straw? The reason why water doesn't come out when you place your finger over the top of the filled straw is that the air pressure acting on the bottom surface of the water results in an equal (and opposite) force to the weight of the water.
Since you essentially have a vacuum over the top of the column (no air pressure, or very little, acting on the top of the column) the water column has no net forces acting on it.
edit: friction plays a part, too, and is partly contributing to the water column staying still.
If a capillary is really thin and walls are hydrophilic, the water will stay inside even if you don't have your finger on it.
If the capillary is a bit thicker and/or the walls are hydrophobic instead, then surface tension won't actually hold the fluid to the capillary. But it will prevent fluid from breaking up into droplets or allowing bubbles to form. That means, entire column of liquid must move as one. That means, additional air can't get in between the closed end and the liquid. Pressure at the top drops, and atmospheric pressure from bellow holds the liquid in. If you remove your finger, pressure equalizes, and liquid is released.
And yes, pipette works the same way. It relies on ambient pressure forcing or holding liquid in the pipette.
(Some of this is redundant to what DocZaius has said, but it's important to point out that surface tension plays a role either way.)
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
