A problem on polynomial fitting
The discussion centers on the challenge of determining whether a specific class of multi-variable polynomials, p(m), can universally and exactly fit another class, q(n), despite their differing forms. The original poster seeks guidance or references to address this fitting problem, noting that previous readings on nonlinear functional analysis and algebra have not yielded relevant insights. The general results, such as the Weierstrass-Stone Theorem, are deemed too broad to apply effectively due to the unique characteristics of p(m) and q(n). Participants express that the vagueness of the classes involved complicates the development of a concrete solution. Overall, the need for more precise definitions and examples is emphasized to advance the discussion.
krete
I encounter a problem on the fitting ability of a special class of multi-variable polynomials. To be specific, I need find whether a special class of multi-variable polynomials, denoted by p(m), where m is the number of variables, can universally and exactly fit all member in another special class of multi-variable polynomials q(n), where n is also the number of variables. Note that p(m) and q(n) have different forms, respectively. Might you please give me some hints or references on this problem? Thank you in advance for you kind help.
Btw, I tried to read some materials on nonlinear functional analysis and algebra. But I could not find a relevant reference. Please note that the general result (e.g., Weierstrass-Stone Theorem) seems to be too general to guide this problem since the form of p(m) and q(n) are special, and the m and n are related.
Mathematics news on Phys.org
The same can be said about the question. Some class for ##p(m)##, another class for ##q(n)## is simply to vague to develop an idea of what could help, and
krete said:
... universally and exactly fit all member ...
isn't of help either.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
