Does the angle at which an object is fired affect its escape velocity?
The escape velocity is the minimum speed needed for an object to leave Earth's gravitational field without further propulsion, calculated using the formula v = √(2GM/R). When fired radially outward, an object will reach "infinity," while if fired downward, it will spiral back to Earth. Firing at an upward angle still allows the object to reach infinity due to energy conservation, as energy is scalar. The trajectory of an object fired at a downward angle can be described as a parabola, and if it does not intersect the Earth, it will also reach infinity. A rigorous proof involves conservation of energy, demonstrating that an object launched at escape velocity will reach infinity regardless of the launch angle.
Bipolarity
The escape velocity of an object on the surface of the Earth is the minimum speed required for it to "break free" from the Earth's gravitational field without requiring further propulsion.
Its value is mathematically determined to be v = \sqrt{\frac{2GM}{R}} with M being the mass of the Earth and R being the Earth's radius.
If the object is fired pointing radially away from the Earth, then it will travel in a straight line and certainly reach "infinity".
If the object is fired pointing radially towards the Earth, it will travel in a straight line and simply accelerate towards the Earth.
My question is what happens if the object is fired at some angle (with the escape speed of course). Most sources say that if it is fired with some upward angle, it will still reach out to "infinity" because of energy considerations, and the fact that energy is scalar.
But if the object is fired with some downward angle, it will not reach out to "infinity" and simply spiral towards the Earth.
What if the object is fired perpendicular to the radial line?
And how can we prove these results using a rigorous approach, rather than a merely observation that energy is a scalar? I am more of a mathematician, so would prefer a very rigorous attempt to address this question.
All help is appreciated. Thanks!
BiP
Hi Bipolarity! :smile:
No, it will follow a parabola.
If the parabola intersects the earth, of course the object will stop!
If the parabola doesn't intersect the earth, the object will "reach infinity" exactly as if it had been fired outward.
That is rigorous. :redface:
Energy shows perfectly rigorously that an object launched at escape velocity will "reach infinity at zero speed", no matter what the angle of launch.
tiny-tim said:
Hi Bipolarity! :smile:No, it will follow a parabola.
If the parabola doesn't intersect the earth, the object will "reach infinity" exactly as if it had been fired outward.That is rigorous. :redface:
Thanks tim, but I don't understand how these claims are rigorous. How can you prove them? Suppose I wanted to prove it without using energy...
BiP
As you get further from the earth, you get closer and closer to flying directly away from it regardless of what angle you started from.
Energy Proof (simple)
This is basically the proof that's given on Wikipedia, very simple and very easy. I' can't prove the parabola thing that tiny-tim wrote about, so you'll have to figure that one out some other way. However, since energy is scalar, as long as you don't run into the planet (like tiny tim said) the energy is conserved as shown.
We start with conservation of energy.
(KE + PE)_1 = (KE + PE)_2
Initial kinetic energy is some velocity, we'll call it ve for escape velocity. Likewise, its potential energy is whatever it is on the surface, at radius r from the planet center. As we go to infinity, the potential energy goes to zero as r goes to infinity, and we'll pretend the kinetic energy goes to zero at the point where r goes to infinity.
Additional notes: m is mass of escaping object, M mass of planet, G gravitational constant.
(1/2)mv_e^2 + (-GMm/r) = 0 + 0
So, we're then left with:
v_e = \sqrt{2GM/r}
Another additional note: I'm not sure why they defined the potential energy the way they did, but that's how they showed it.
the "parabola thing" is easy
a small body near an isolated mass must follow an ellipse (eccentricity < 1) a parabola (eccentricity = 1) or a hyperbola (eccentricity > 1)
as you increase the speed (for a fixed direction at a fixed position), you increase the eccentricity
if it's an ellipse, the body will never "reach infinity"
the smallest value of eccentricity, and therefore the smallest speed, for which the body can "reach infinity" is when the path is a parabola :smile:
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
