Searching for Josephson Junctions
  • Thread starter Thread starter forex10
Searching for off-the-shelf Josephson Junctions reveals limited options, primarily from specialized semiconductor companies that utilize Nb technology, requiring cooling to around 4K. The discussion highlights the challenge of finding alternatives, as ceramic superconductors like YBCO, while having a higher critical temperature of 92K, still necessitate cryogenic cooling, ideally to 77K or lower. The lack of access to cryogenic equipment complicates the search for suitable junctions. Users emphasize the need for more accessible options for experimental purposes. Overall, the availability of Josephson Junctions remains constrained by cooling requirements and specialized manufacturing.
forex10
Hello,
I am searching for off the shelf Josephson Junctions for experimental purposes. All I have found is a specialized semiconductor design/fabrication business. I am not a huge expert on physics or electronics, but I would think they would be more available than what I have found. Also, I am not looking for squids. I hope some one can help me out.
Joe L.
Do you have access to liquid helium, or a 2-stage cryocooler?
There are a few companies that could probably sell you chips with Josephson junctions, but they all (maybe with one exception) use Nb technology, i.e. you need to cool the junction down to around 4K.
No I do not have access to any cryogenic equipment. The reason I wanted to find ceramic superconductors was to try to avoid that, but from what I am learning ceramic alloys SC's could still be enhanced with some extra cooling. Thanks for your reply.
Even with ceramic superconductors you still need cryogenic equipment, YBCO has a Tc of 92K; but you really need to be down at 77K (liquid nitrogen), and ideally colder, in order to operate Josephson junctions.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
