Mercury in glass-laboratory thermometer doesn't stick to glass?
The discussion revolves around the reasons why mercury in glass laboratory thermometers does not adhere to the glass. Participants explore various factors including viscosity, surface tension, and molecular interactions between mercury and glass, as well as comparisons with water's behavior in similar contexts.
  • Some participants suggest that the low viscosity of mercury contributes to its inability to stick to glass.
  • Others argue that viscosity relates more to molecular cohesion rather than adhesion to surfaces, noting that mercury is nonpolar while glass is polar.
  • One participant mentions that mercury's high surface tension prevents it from adhering to glass, stating that it only sticks to materials it can react with to form amalgams.
  • Another participant points out that water, being polar, does not adhere to glass either, suggesting that cleanliness of the glass surface may affect adhesion.
  • Some participants highlight the differences in cohesion and adhesion between mercury and water, explaining that mercury's cohesive forces are stronger than its adhesive forces with glass, resulting in a convex meniscus.
  • A humorous comment likens mercury's preference to stay together to being "introverted," emphasizing the strength of Hg-Hg bonds compared to Hg-glass bonds.
Participants express differing views on the primary reasons for mercury's behavior in relation to glass, with no consensus reached on the most significant factors influencing adhesion or lack thereof.
Some claims rely on assumptions about molecular interactions and the cleanliness of surfaces, which are not universally agreed upon. The discussion includes references to viscosity and surface tension without resolving the implications of these properties fully.
Fly_High
Why the mercury in glass-laboratory thermometer doesn't stick to glass?
Chemistry news on Phys.org
Hi, the reason is that the viscosity of Mercury is low 0.159*10^-2 (kg/ms).
(for water = 0.105*10^-2 (kg/ms))
You can view more intuitively if you know for example the Glicerine viscosity
(139.3 * 10^-2 ( kg/ms), three order of magnitude higher) :smile:
Viscosity more has to do with how much the molecules of a liquid "stick" to each other and not to another substance like glass. Mercury doesn't adhere to glass well because it's nonpolar while glass is polar.
I'm not agree whit your opinion. Water is polar and it doesn't andhere to glass.
"[URL
" Viscosity is a measure of the resistance of a fluid to deform under shear stress. It is commonly perceived as "thickness", or resistance to flow."[/URL]
Because this resistance, the fluid who have high viscosity take more time to return to inicial position, in this case, to the bottom of termometer ( for the gravity strength).
Cheers.
There are two reasons : first mecury has very high surface tension, i can't remember but probably about 4 or 5 times higher than that of water. It is so strong that any adhesion force can not compete with. According to my experience, Hg does not stick to any material except for the case it react to become an amalgam. Secondly, water is polar and so is glass. If water does not stick to glass, probably be the glass surface is not clean.
When you pour water out of a glass container, does all the water flow out? Nope, some stays stuck against the walls of the container!
Some info about thermometers: http://home.earthlink.net/~dmocarski/chapters/chapter6/main.htm
And from that page "Another reason is that water sticks to glass and mercury and alcohol don't."
Yeah, I know it's an old thread but it popped up when I was googling the viscosity of mercury and thought I would post a useful answer regarding the OP for others that end up here the same way I did.
Anyhow, high cohesion is the reason mercury doesn't wet the glass. Mercury molecules are attracted to each other more than the glass. That is why the meniscus of mercury in a glass container is convex.
Water on the other hand has a low amount of cohesion and it is attracted to the glass more than itself. That's why the meniscus of water is concave. Relative to glass, the adhesive force of the water is higher than it's cohesive force. Place it on a hydrophobic surface, like a waxed car, and it will behave as mercury does with glass and bead up from it's own cohesive force.
Because Hg-Hg bonds in the liquid metal are much stronger than Hg-glass bonds, so mercury prefers to stay...with itself (it's an introverted:smile:)
