Simple function questions - checking answer.
  • Thread starter Thread starter Michael_Light
    Function
The discussion revolves around finding the range of the composite function fg(x) and the domain of fg(x) for two given functions. For the first problem, the correct range is identified as 3 ≤ y ≤ 19, while the initial answer of y ≥ 3 was incomplete. In the second problem, the domain of fg(x) is clarified to be x ≥ 25, as the range of g(x) must align with the domain of f(x), which starts at x ≥ 5. The participants emphasize the importance of correctly interpreting the composite function notation and ensuring that the outputs of g(x) fit within the constraints of f(x). Overall, the key takeaway is the necessity of matching the range of g(x) to the domain of f(x) for accurate results.
Michael_Light
1) Given f(x)=x+3, x∈R and g(x)=x2,x∈R,0=<x=<4, find the range of composite function fg(x).
2) Given f(x)=x+1,x∈R,x>=5 and g(x)=x1/2, x∈R,x>=0. Find the domain of fg(x).
For 1), the answer 1 get is y=>3 , but the answer given is3=<y=<19.
2) the answer i get is x>=0 , but yet the answer provided is x>=25.
So what answers do you guys get? Anything wrong with the answers provided by the answer sheet? Cause i couldn't find anything wrong with my solutions... Thanks in advance.
You almost had #1. You just didn't handle the other part of the inequality!
If you write out your work we can find where you went wrong.
The domain of f(g(x)) consists of all x-values is such that the g(x)-values maps to the domain of f(x). It can't be x ≥ 0 because the range of g(x) would be g(x) ≥ 0, and you would have values that are not permitted in the domain of f(x).
If you restrict the domain of f(g(x)) to be x ≥ 25, then the range of g(x) would be g(x) ≥ 5, which "matches" the domain of f(x). So x ≥ 25 is right.
I finally managed to get the correct answer for 1), can you help me with 2)? ><
But how can i obtain x≥ 25 mathematically?Here is my approach... fg(x) = f(x1/2) = x1/2+1, x≥0. Domain of fg(x)= domain of g(x), hence domain of fg(x) is x≥0. Can anyone correct me?
You really should write this as f(g(x)), not fg(x), which is what is used for the product of two functions.
You are given that the domain of f is restricted to x >= 5. So although there are many values of x that are in the domain of g, there are some values of g(x) that aren't in the domain of f.
Some examples that use selected values of x.
x = 0. g(0) = sqrt(0) = 0. Can we evaluate f(0)? No, because 0 is not >= 5.
x = 1. g(1) = sqrt(1) = 1. Can we evaluate f(1)? No, because 1 is not >= 5.
x = 4. g(4) = sqrt(4) = 2. Can we evaluate f(2)? No, because 2 is not >= 5.
x = 9. g(9) = sqrt(9) = 3. Can we evaluate f(3)? No, because 3 is not >= 5.
Do you see where I'm going with this?
For #2:
Since f(x) is defined only for x ≥ 5, find the values of x for which g(x) ≥ 5.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
