Understanding the Time Evolution of Velocity in a Variable Electric Field
The discussion revolves around the time evolution of the velocity of a charged particle in a variable electric field. Participants explore the implications of the electric field's variability on the presence of an induced magnetic field, the application of Newton's second law, and the use of Maxwell's equations to analyze the situation. The scope includes theoretical considerations and mathematical reasoning related to electromagnetism and relativistic dynamics.
  • One participant questions whether an induced magnetic field should be considered alongside the variable electric field affecting the particle's motion.
  • Another participant suggests that in a symmetric setup, there may be regions without magnetic fields, specifically at the center.
  • A reference to a book on transient electrical events is provided, indicating varying levels of sophistication in modeling electric and magnetic fields from Maxwell's equations.
  • Some participants clarify that in the particle's rest frame, only electric forces operate, while in other frames, the Lorentz force law applies, which includes both electric and magnetic forces.
  • There is a discussion about the relationship between time-varying electric and magnetic fields, emphasizing that time variation in one typically implies the presence of the other, as described by Maxwell's equations.
  • Concerns are raised about the specifics of the system generating the electric field and whether the problem is ill-defined without additional context regarding the source of the fields.
  • One participant expresses confusion about not obtaining correct results when applying Maxwell's equations, seeking clarification on boundary conditions and specific system details.
Participants express differing views on whether an induced magnetic field should be considered in the context of a time-varying electric field. There is no consensus on the necessity of including the magnetic field, as some suggest it may be negligible while others argue for its consideration based on Maxwell's equations. The discussion remains unresolved regarding the specifics of the system and the application of the equations.
Limitations include the lack of clarity on the system configuration generating the electric field and the assumptions regarding the time variation of the electric field. The discussion also highlights the complexity of applying Maxwell's equations to specific scenarios, which may lead to confusion in obtaining results.
lailola
Hello! This is my doubt:
I have a particle with charge q and mass m with a relativistic velocity v·u_x in a region of electric field E = E_0 cos (wt)·u_z. I want to calculate the time evolution of the velocity.
I would use the 2nd law of Newton, so that dp / dt = F
where p = gamma·m·v·u_x and F = q (E + v·u_x ^ B).
The thing is that as the electric field is variable, it is assumed that there will be an induced magnetic field acting on the particle (or not?). The first thing is that I don't know if I have to consider a field B acting on the particle and the second is that, in that case, when I try to calculate B, I use Maxwell's equations but I get results that do not fit.
So is there only electric force or no electric and magnetic force?
Thank you.
There should be a spot without magnetic fields - in a symmetric setup, this is the center. Everywhere else, it can get tricky.
In his book, The Lightning Discharge, Uman considers models of varying levels of sophistication for computing time dependent electric and magnetic fields from Maxwell's equations. Buy it, it's cheap.
Here is a link to a variety of publications and patents dealing in transient electrical events, Helmholtz equations, etc. http://www.ee.psu.edu/Directory/FacultyInfo/Pasko/PaskoPublications.aspx
Respectfully,
Steve
lailola - your problem is not specified terribly well, but a few general observations can be made. in the rest frame of said particle, only electric forces qE operate. In any other Lorentzian frame, the relativistically exact Lorentz force law expression F = q(E+vxB) applies, where E, B, and v are all evaluated in that frame. Sticking with that one frame, integration over time using F = q(E+vxB) = dp/dt = d(γmv)/dt then gives the velocity evolution, where γ = 1/√(1-(v/c)2). This assumes no implied back-reaction coupling to whatever source produces the applied field, and further assumes radiative back reaction is negligible. You have correctly identified the relativistic energy part of all this re coupling to velocity - the remainder seems straightforward to me (well ok it gets to be a messy integro-differential equation likely needing numerical evaluation - but then what's in the detail :smile:)
But..in the 'laboratory' rest frame, where the particle is moving with velocity v, is there an external magnetic field B (due to time-dependent E) that I have to consider? I don't know how could it be calculated..
thank you for your answers!
Ah ok - it's the external source relation between time varying E and B that's bothering you. Details will depend on the source configuration - i.e. is it idealized to the field between the plates of a capacitor with time-varying voltage, or that owing to a solenoid with time-varying current etc. In general, one has the Maxwell eqn's as guide. Bottom line is that except at a particular point in space and time, time variation of E implies the existence of a time varying B also, and vice versa. That follows from the relations curl E = -dB/dt, and curl B = c-2dE/dt (in vacuo). These curl relations imply there must be both fields present if time variation of either one exists.
In the lab frame, you can have a magnetic field.
And to evaluate this in the electron rest frame, you have to convert your fields - where the conversion (given by the velocity of the electron) changes in time. Not sure whether this helps or not...
The thing is that i haven't got a conductor as capacitor or a solenoid, I have a point charge suffering a time-dependent external E. My problem is that I'm not sure if I have to consider that the point charge is also suffering an induced external B, or if there's no B.
Well sorry but in that case your problem is ill-defined. The time and space relations between externally acting E and B do depend on the details of whatever system of charges and currents generate the E and B. If as it seems your home-work assignment specifies only a time-varying E, then my guess is it implies such time-variation is slow enough to assume a negligible B field - so just work from an E only. And blame your teacher for being sloppy in asking the question if that's 'the wrong answer'! :smile:
Ok, I think you must be right. Only a last question... Why don't I get a correct result when I use the two Maxwell equations that you have writen? I have the expression of E, so..the only value that isn' known is B.
Those curl eqn's must be applied to a specific system and then solved using boundary values - e.g. tangent component of E vanishes at surface of a perfect conductor, likewise for normal component of B. it can get quite messy in detail! You probably have some good textbooks that give worked examples.
  • · Replies 22 ·
