Conservation of energy in case of rotating falling rod
The discussion revolves around the conservation of energy in the context of a vertically standing rod that begins to fall and rotate after being disturbed. Participants explore the relationship between potential energy, kinetic energy, and the role of forces such as the normal force during the rod's motion, considering both translational and rotational aspects.
  • One participant proposes that the change in potential energy (PE) can be expressed as 1/2 I w^2 + 1/2 M v^2, questioning the applicability of this formula due to the rod's sliding motion at the left end.
  • Another participant confirms that the formula for kinetic energy (KE) is correct for a general body, but there is confusion regarding the role of the normal force in the energy equation.
  • A participant suggests expressing the torque due to the normal force as a trigonometric function and integrating it over the angular displacement to calculate work done.
  • There is a discussion about the normal force being vertical while the displacement is horizontal, leading to the assertion that the work done by the normal force is zero.
  • One participant argues that the normal force applies a clockwise torque and must do work over the angular displacement, raising questions about the source of torque in the center of mass (CM) frame.
  • Another participant emphasizes the importance of calculating work done from forces rather than torques, noting the complexity of determining the effective components of the normal force.
  • There is a clarification that one component of the normal force does work while another cancels it out, leading to the conclusion that the normal force does no work because it is perpendicular to the displacement.
Participants express differing views on the role of the normal force in the energy equation and whether it contributes to work done. There is no consensus on how to incorporate the normal force into the calculations, indicating an unresolved debate.
The discussion includes assumptions about the motion of the rod, the nature of forces acting on it, and the definitions of work and torque. The complexity of resolving the normal force into components adds to the uncertainty in the analysis.
Perpendicular
Suppose we have a rod standing vertically and then slightly disturbed so it begins to fall. After it falls through some height or angle assuming a clockwise rotational fall I can see that the left end is sliding on the surface ( for simplicity I'm ignoring friction ) horizontally. Here I assume that I know the change in height although knowing length of rod and angular displacement would work as well.
In that case, would I be right to say that the change in PE equals
For I , v and w at the Center of mass ? While that is normally the case for combined translation and rotation, I'm having doubts using that expression here as the leftmost end doesn't seem to rotate about the CM, it's sliding instead. Should I try to take the CM's source of torque ( the normal force on the leftmost point of contact ) and work from there to obtain some results ?
Hi Perpendicular! :smile:
(try using the X2 button just above the Reply box :wink:)
Yes, that is the correct formula for KE of a general body.
Keep calm and carry on! o:)
well it is but I'm confused regarding what to do with the normal force N...supposing some angular movement theta I am thinking of expressing the torque due to N as some trigonometric function and then integrating over dtheta to get work done due to torque by normal force.
Then I think the eqn will look like (mgh) + (Work done due to the torque by normal force) = (Rotational energy from CM frame) + (KE w.r.t CM )
Am I right ? Or am I wrong in taking into account the work done by the normal force ?
the normal force is vertical, but the displacement of its point of application is horizontal, so the work done is zero :wink:
(only the friction force would do work, so only the friction force affects the energy equation)
(mgh) = (Rotational energy from CM frame) + (KE w.r.t CM )
The body rotates clockwise and the normal force applies a clockwise torque which must do some work over the angular displacement, right ? And from the CM frame, where else would you even get torque ?
after all work = torque.angular change as well.
right :smile:
but … that's only using the component of the normal force that makes the torque
you're ignoring the rest of the normal force (and it's very difficult to work out what that is!)
please calculate work done from forces, not from torques! :wink:
So basically one component of N does work while the other cancels that work out ?
basically, N does no work because it is perpendicular to the displacement!
but if you resolve it into perpendicular components at an angle to N (not 0° or 90°), then yes, the work done by each component cancel out! :smile:
  • · Replies 23 ·
  • · Replies 77 ·
  • · Replies 30 ·
