Can a gyroscope be used to stabilize a levitating globe?
  • Context: Undergrad
  • Thread starter Thread starter sagitta
    Project
The discussion revolves around the feasibility of using gyroscopic motion to stabilize a levitating globe, particularly in the context of a project for an Experimental Physics class. Participants explore various methods of achieving levitation, including overcoming Earnshaw's theorem.
  • Exploratory, Technical explanation, Debate/contested, Experimental/applied
  • One participant proposes using eddy currents to stabilize a conductor as a method for levitation, but notes it requires high voltage.
  • Another participant suggests using a feedback circuit to control the strength of an electromagnet, indicating it is the preferred method for their project.
  • A participant raises the idea of incorporating a gyroscope inside the globe for stabilization, questioning if a gyroscope exists that does not require prior spinning.
  • One reply discusses the possibility of using spinning magnets as a support mechanism, but questions the practicality of balancing a spinning interior within a static globe.
  • Another participant clarifies that the globe is intended to remain static, expressing a preference for the feedback system due to its potential for greater stability.
Participants express differing views on the methods of stabilization, with some favoring feedback systems while others explore the potential of gyroscopic stabilization. The discussion remains unresolved regarding the practicality and effectiveness of these approaches.
The discussion highlights limitations such as the need for additional motors for spinning interiors and the challenges of balancing mechanisms within the globe. There are also unresolved questions about the feasibility of using gyroscopes without prior spinning.
sagitta
Hello,
I am a student and this semester I am doing a project in Experimental Physics class. We plan to make a levitating globe! We have already researched on methods of overcoming Earnshaw's theorem and chose two:
1) Using eddy currents to stabilize an object (conductor)
More or less simple design, but requires too much voltage.
2) Using a feedback circuit to control the strength of the electromagnet.
We have already found some SOP and will research more and figure out by ourselves. This 2nd method is currently chosen as the main one.
But I have been thinking about levitrons and how they use gyroscopic motion to create the equilibrium point... Usually it requires a spinning top, which is not convenient since we need to have a globe. But I was thinking about gyroscopes and this idea fascinates me.
Is it possible to somehow install a gyroscope inside the globe to stabilize the levitation? Is there sort of a gyroscope that doesn't need to be spinned beforehand like spinning tops?
- Spinning magnets as support should be possible
- A spinning interior for a static globe... I think that needs an additional motor in the globe, and it sounds tricky to balance.
Spinning magnets? By "support" you mean as a base or the globe?.. Because I think the globe is supposed to be static...
I guess we'll stick to the feedback systems, they require some soldering and more calculations but seem to provide more stability.
Thank you for the reply!
The base, which allows levitation of the globe.
  • · Replies 51 ·
