How Can I Fix Inconsistent Page Sizes in My Ebook?
  • Thread starter Thread starter leroyjenkens
The issue of inconsistent page sizes in an ebook, where some pages are significantly smaller than others, can be frustrating. This problem often arises from the ebook format and the device being used, similar to how PDFs with mixed orientations can behave. A practical solution is to adjust settings to display one page at a time, which can alleviate the need for constant zooming. For a more permanent fix, users can consider using tools like ImageMagick to separate the PDF into individual pages, resize the smaller pages to match the larger ones, and then recombine them into a single document. This method, while potentially tedious for large ebooks, can effectively standardize page sizes for a smoother reading experience.
leroyjenkens
I have an ebook with some pages are normal size, and some pages are small. I'll be reading a page, scroll down, and I'll see like 4 pages in a row that are like 1/6th the size of the one I'm reading, then I scroll down some more and I'll see the next pages normal size, and so on. Is there any way to fix this? It's extremely annoying having to zoom in 6 times on the small pages, and then zoom back out for the normal size pages every time I cross one of those pages that are tiny.
Thanks.
Computer science news on Phys.org
From what I know it depends on the ebook (device) and ebook format (mobi? pdf?), so you will not get any general answer.
This is the same behavior with pdfs made from photo albums scrolling through landscape and portrait photos. The best you can do is set your prefs to do page at a time.
You might be able to get a tool to break up the pdf into individual pages then resize the small ones to the same size as the larger ones and then recombine them as a single pdf.
Image Majik tools could help to do some of the work:
http://www.imagemagick.org/script/index.php
and/or these tools:
http://www.ehow.com/how_5093105_break-pdf-file-parts.html
Image-majik convert command can resize photos:
http://www.imagemagick.org/script/convert.php
And here's someone with a similar problem who used imagemajik to fix the problem:
http://stackoverflow.com/questions/9706046/imagemagick-convert-multiple-images-to-pdf-size
Likes 1 person
Thanks a lot. Setting it to page at a time is the best bet for me, I think, because the book has over 1300 pages. Resizing about half of those would be extremely tedius.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
