Is Peano Arithmetic Essential for Understanding the Logic-Math Connection?
  • Thread starter Thread starter robertjford80
    Arithmetic Peano
Learning Peano Arithmetic (PA) is deemed essential for grasping the connection between logic and mathematics. The discussion highlights the potential value of a specific book and a PDF resource on PA, questioning whether the latter can adequately substitute for the former. Participants note that while some areas of mathematical logic may not require extensive knowledge of PA, a foundational understanding is beneficial. The conversation also touches on the challenges faced by those new to logic, emphasizing the importance of prior knowledge in related fields like proof theory and set theory. Overall, a solid grounding in PA and related topics is recommended for a deeper comprehension of mathematical logic.
robertjford80
It seems that learning PA is necessary if you want to understand the relationship between logic and math.
Should I track down this book at the library, a chore which will take up an hour of my precious time
The principles of arithmetic, presented by a new method" in Jean van Heijenoort, 1967. A Source Book in Mathematical Logic, 1879–1931. Harvard Univ. Press: 83–97.
Or will this pdf I found on the internet serve the same purpose?
http://ocw.mit.edu/courses/linguist...pring-2004/lecture-notes/peano_arithmetic.pdf
Mathematics news on Phys.org
Logic is not my particular area of expertise, but I imagine the level of understanding needed depends on where exactly your interests lie. There are large parts of mathematical logic that depend little on a deep knowledge of PA.
Unless you have some prior grounding in logic some parts of that pdf will probably be rough going. It mentions connections to model theory and second-order logic at the end, and while it does not appear to require anything especially deep from either, some understanding will undoubtably be missed without it.
I already took a look at it. I keep putting the cart before the horse. I have three books on intro to proof theory and three books on intro to set theory. I'm going to read those first before I give mathematical logic a second shot because my first shot at mathematical logic resulted in failure.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
17K
