Curvature of a circle approaches zero as radius goes to infinity
As the radius of a circle approaches infinity, its curvature approaches zero, which can be mathematically expressed as lim (r → ∞) (1/r) = 0. The curvature of a circle is defined as the reciprocal of its radius, leading to the intuitive understanding that larger circles have less curvature. However, the concept of dividing infinity by infinity is indeterminate, complicating the discussion of values like pi in this context. The conversation also touches on the real projective line as a theoretical representation of such circles. Overall, the mathematical expression captures the relationship between increasing radius and decreasing curvature effectively.
BOAS
Hello,
this isn't a homework problem, so I'm hoping it's okay to post here.
I would like to know the correct way to mathematically express the idea in my title. It is intuitively obvious that as the radius of a circle increases, it's curvature decreases.
I looked it up and found that the curvature of a circle is equal to the reciprocal of it's radius. Certain assumptions are often made when looking at lenses, i.e the wave fronts reaching the lens are parallel, or have 0 curvature - In other words, the object distance is infinitely far away.
But, 1/∞ ≠ 0
So how do I express it properly?
In words, I think it goes something like this - As the radius tends towards infinity, the curvature of the circle tends towards zero.
Mathematics news on Phys.org
Wouldn't you just use the lim 1/r expressions with r-> infinity to express it?
That would be my guess but I'm unsure of how to formulate that.
lim_{r \rightarrow ∞} \frac{1}{r} = 0
Like that?
If you imagine a circle with infinite radius, then its circumference is also infinite.
Then what would be the value of pi be? Infinite divided by infinite. Can you say what
it is?
I think the real projective line may be a picture of this kind of "circle":
http://en.wikipedia.org/wiki/Real_projective_line
The same as always. ##\pi## is a constant (its value never changes).
it is?
No. There are several indeterminate forms, including [∞/∞], [0/0], [∞ - ∞], and a few others. These are indeterminate, because you can't determine a value for them.
They usually come up when we are evaluating limits of functions.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
