Understanding Electrical Network Theory Equations: Confusion on Pg 101
  • Thread starter Thread starter jesse7771
    Formulas
The discussion centers on confusion regarding equations 67-72 in Balabanian and Bickart's electrical network theory, specifically on page 101. The equations relate to the separation of sources from passive elements in a network, with A representing a node graph matrix and B a loop matrix. The author is attempting to understand how these equations facilitate nodal and loop analysis for circuits but finds the notation unclear. There is a mention of a lack of comprehensive resources, as the only reference found was from incomplete graduate-level notes. Clarification on these equations is sought to better grasp their implications in network analysis.
jesse7771
Im currently reading through the classic book on electrical network theory Balabanian and Bickarts electrical network theory. And I am getting confused on page 101, and the set of equations their... Eq's 67-72 dealing with accompanied sources and what exactly he's trying to imply with these equations... I am thinking from the direction he goes afterwards that these equations are dealing with the separation of sources from the passive elements in the network, but the way they are written in giving me a hard time.
The equations are:
AI=AIg
BV=BVg
And I-Ig=B'Im
V-Vg=A'Vn
Thanks for any input
Can you provide a picture of the page in question? It might help generate some responses.
I don't have a smart phone or scanner sorry... The author going over a generalized network branch, and how you can treat all sources as accompanied for the sake of dealing with sources and passive elements seperatly in a network. This whole chapter is going over topology in network analysis, and where A is a node graph matrix and B is a loop matrix and ig and vg are source column matrixes.
Sorry for this oddly specific question, the author is using it to formulate nodal and loop analysis for circuits. My only thought would be that if Ai=0 (KCL) and I can be separated into a current though the passive element and a current through the source in a generalized branch then A(ip-ig)=0 then Aip=Aig, where ip would be the current through the parrallel passive element in the branch and ig would be the parrallel branch. But from the notation it is clear that i in the would be the branch current column matrix, meaning simply the current through the branches which seems natural to assume all the current through the branches. The 3rd equation would follow where i-ig=B'im, but this is not what the equations are saying at all.
The only discussion I could find of this was in a graduate level network theory class's notes but they are incomplete in this section... http://classes.engr.oregonstate.edu/eecs/fall2013/ece580/Lecture%20Notes/p1-21.pdf The generalized network branch is on page 17 and page 18 goes into nodal analysis but uses a slightly different notation which seems to be more consistent with KCL and KVL
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
