Artificial Means of Jumping Higher
  • Thread starter Thread starter Haftred
    Means
The discussion explores methods to artificially increase jump height, primarily focusing on the limitations of using springs due to the impracticality of achieving necessary compression and spring constants. Alternatives like rockets and robotic leg devices are suggested, though concerns about safety at high acceleration are noted. The conversation also highlights the potential of trampolines and specific techniques, such as using both legs for takeoff, to enhance jumping ability. Additionally, the influence of springy surfaces in gymnastics is mentioned as a factor in achieving greater heights. Overall, various innovative approaches to augmenting jump height are considered, emphasizing the importance of kinetic energy addition.
Haftred
I am looking to see if there is a discrete way to increase the height one can jump, and the only way I could see it feasibly being done is with a spring. However, the spring could only realistically be supressed a few centimeters, and the spring constant needed would need to be relatively large, say 100,000 N / m. Even if there were a spring with this large spring constant, it would be almost impossible to supress it the needed few centimeters. Therefore, it seems that springs would not do anything. Any ideas about artificial means of jumping higher?
Yes, except after a certain point, the acceleration you experience would kill you. You could use some sort of rockets, robotic leg type devices, etc.
It's kind of a quirky question. If you jump onto a spring and simultaneously jump again, you are using the spring's stored energy from your fall plus the energy you are exerting to jump again.
So really what you are asking is, "how can I add kinetic energy", and there's a LOT of ways to do that!
What about a trampoline? If you're referring to the rules of a high jump in track events, note that the rules require that only one leg is planted. If a gynmastics type flip flop move were allowed, using a two foot take off, the height would be much larger. If the surface were allowed to be springy, as in power tumbling (not an olympic event), the heights are quite high.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
