How do I prove that x + 1/x is greater than or equal to 2 if x > 0
  • Thread starter Thread starter JasonJo
To prove that x + 1/x is greater than or equal to 2 for x > 0 without using calculus, one can start by rearranging the expression into the form x^2 - 2x + 1 ≥ 0. This simplifies to (x - 1)^2 ≥ 0, which is always true for any real number x. Since x is constrained to be greater than 0, the inequality holds, confirming that x + 1/x is indeed greater than or equal to 2. Additionally, using the arithmetic-geometric mean inequality reinforces this conclusion, as it leads to the same result. Thus, the proof is established through algebraic manipulation and properties of inequalities.
JasonJo
How to prove this?
i'm not allowed to use calculus either.
i got that x + 1/x is greater than zero, but i can't get greater than or equal to 2.
Assume for contradiction that x > 0 yet x + 1/x < 2. Transform it into a quadratic and show that this is impossible.
Hint: (x - 1)^2 > 0.
Regards,
George
First make the equation into x^2-2x+1 >= 0 by rearranging and multiplying by x.
You should find it is (x-1)^2 so for any x (not just x>0) this function is greater than or equal to 0 because of ^2.
For your situation it is obvious that x>0 which is certainly true for the factorised function. Therefore you have proved that x+1/x is greater than or equal to 2.
before i posted this, i did get the algebraic manipulation of (x-1)^2, but i thought that only proved it for x greater than or equal to 1. but i guess since it's an equivalent statement, it's the same thing.
thanks everyone
Another method is arithmetis-geometric mean inequality.
Strictly speaking a proof would work the other way:
for any x, (x-1)^2\ge 0 so x^2- 2x+ 1\ge 0.
Adding 2x to both sides, x^2+ 1\ge 2x. Finally, dividing both sides by the positive number x, x+ \frac{1}{x}\ge 2
