Solving a Trig Question: Identifying Independent & Dependent Variables
In the discussion about identifying independent and dependent variables in a trigonometric context, it is clarified that r and theta are variables rather than fixed points. The conversation emphasizes that in pure mathematics, neither variable is inherently dependent on the other, as equations can often be solved for either variable. However, in practical measurements, one variable can be designated as independent while the other is dependent based on how they interact. The distinction is crucial for understanding relationships in mathematical functions versus real-world applications. Overall, the thread highlights the importance of context when determining variable dependencies.
WillyTech
Here is a trig question that I've been thinking about. I want to know which one would be the independant and the dependant of the points
(r , theta)
1) r and theta are not points, they are variables.
2) There is "dependency" in pure math. Neither variable can be said to be dependent upon the other. Even if you wrote down a function of these two variables, you could, in general, solve the equation for either variable.
3) Dependencies occur in measurements, where you change one variable (the independent variable) and observe changes in the other (the dependent variable).
- Warren
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
