Solving "An Person Pushes a Box Up a Hill: A Physics Problem
  • Thread starter Thread starter danago
    Box Hill Physics
The physics problem involves calculating the acceleration of a box being pushed up a 30-degree incline with a force of 450N, a mass of 20kg, and a friction force of 20N. The correct approach requires resolving the forces acting on the box, including gravitational and frictional forces. The calculated acceleration is 16.6 m/s², which is significantly higher than the initially suggested 1.9 m/s². This discrepancy indicates a misunderstanding in the application of Newton's second law in the context of inclined planes.
  • Understanding of Newton's second law of motion
  • Basic knowledge of force resolution on inclined planes
  • Familiarity with gravitational force calculations
  • Concept of frictional force in physics
  • Study the principles of force resolution on inclined planes
  • Learn about the calculations involved in determining net force and acceleration
  • Explore the effects of friction on motion in physics
  • Review examples of similar physics problems involving inclined planes
Students studying physics, educators teaching mechanics, and anyone interested in solving problems related to forces and motion on inclined surfaces.
danago
Hey. I've been given this problem:
"An person wishes to push a box up a hill, inclined at 30 degrees. He is able to push with a force of 450N. If the box has a mass of 20kg, and a force of friction with magnitude 20N applies, what is the acceleration of the box?"
I drew a diagram, and came up with this:
http://img135.imageshack.us/img135/1124/incplaneob0.gif
What i did was resolve all of the forces into their components (parallel and perpendicular to the slope), including the weight and normal force, and then add them all.
I got an answer of 16.6 ms^-2, but apparently the answer is 1.9 ms^-2. Would someone be able to maybe quickly work it out, and tell me what the real answer is?
Thanks very much,
Dan.
(450-20-20*9.81*sin(30))/20 = 16.595, so you should be correct. The box should have an acceleration plenty over 1.9 m/s2 even if the hill was vertical.
ok thanks for confirming that :-)
13K
37K
