Question: Can the Decreasing Sequence be Proven Using Different Methods?
The discussion centers on proving that the sequence {ak} = {(1 + 1/k)^{-k}} is decreasing. Initial attempts involved analyzing the difference a_{k+1} - a_k, but participants noted that the ratio a_{k+1}/a_k being less than 1 is a more appropriate method. A suggestion was made to express the sequence in the form e^f(k) and analyze the derivative f'(k) to determine its sign for large k, indicating the sequence's behavior. The conversation highlights the need for careful consideration of mathematical proofs and the importance of using the correct approach to establish the decreasing nature of the sequence. Ultimately, participants seek a valid method to confirm the sequence's decreasing property.
murshid_islam
i have to prove that the sequence {ak} is decreasing, where
\{a_k\} = \{\left({1+\frac{1}{k}}\right)^{-k}\}
this is what i did:
a_k = {\left(\frac{k}{k+1}}\right)^k
a_{k+1}-a_{k}
= {\left(\frac{k+1}{k+2}}\right)^{k+1}-{\left(\frac{k}{k+1}}\right)}^{k}
= {\left(\frac{1+\frac{1}{k}}{1+\frac{2}{k}}}\right)^{k+1}-{\left(\frac{k}{k+1}}\right)^{k}
< {\left(\frac{1+\frac{1}{k}}{1+\frac{1}{k}}}\right)^{k+1}-{\left(\frac{k}{k+1}}\right)^{k}
= 1 - \left({\frac{k}{k+1}}\right)^{k}
< 1-1 since \left({\frac{k}{k+1}}\right)^{k} < 1
therefore, a_{k+1}-a_{k} < 0
therefore, the sequence is decreasing.
am i right?
Mathematics news on Phys.org
Hmm..no
The RATIO between the terms should be less than 1, not the DIFFERENCE!
The difference should be less than 0
Suppose we take the sequence 1/2, 1/2, 1/2.
ak+1 - ak = 0 < 1.
Therefore, the sequence is decreasing :P
arildno said:
Hmm..no
ok, i made a stupid mistake. i have edited my proof. is it correct now?
No, it is not.
The reason is that since the last fraction is LESS than 1, the DIFFERENCE between 1 and the fraction is GREATER than the difference between 1 and 1.
Your first bound is too crude to derive the result.
I suggest the following:
Put the expression under the form of e^f(k). The derivative of that expression would be e^f(k) * f'(k). Knowing that e^f(k) is positive for k sufficiently large, find the sign that f'(k) assumes for an also sufficiently k. If the sign is negative, the expression e^f(k) * f'(k) is negative for this value of k and beyond, and you have proven that e^f(k) is decreasing.
Edit: you will find f(k) = ln (1 + 1/k) * - k. If y = ln (1 + 1/k), y' = -1/k(k+1) and f'(k) = -ky' - y = 1/(k+1) - ln (1 + 1/k).
Now (unfortunatly), this is not relevant. We are confronted to another inequality, ln (1 + 1/k) > 1/(k+1).
Sorry that I've wasted so much time... maybe the second inequality would help, but I doubt it. To compensate I'll give you another proof , we have:
(1+1/k)^k is increasing, for
(1+1/n)^{n} = 1 + n\frac{1}{n} + \frac{1}{2!}(1-\frac{1}{n})+ ... + \frac{1}{n!}(1 - \frac{1}{n})(1 - \frac{2}{n})...(1 - \frac{n-1}{n}).
This is simply by using the binominial theorem. Now if,
S_n = 1 + n\frac{1}{n} + \frac{1}{2!}(1-\frac{1}{n})+ ... + \frac{1}{n!}(1 - \frac{1}{n})(1 - \frac{2}{n})...(1 - \frac{n-1}{n}),
then S_m > S_n. Since (1+1/m)^m = S_m + ..., then (1+1/m)^m > (1+1/n)^n
and
(1+1/m)^-m < (1+1/n)^-n
Thus the expression is decreasing. It should be noted that this is only a proof for integrer values of n.
Werg22 said:
you will find f(k) = - ln (1 + 1/k) * k. You have y = ln (1 + 1/k), y' = ln k/(1 + 1/k)
is it correct?
if y = \ln\left(1+\frac{1}{x}\right) then i get y&#039; = \frac{-1}{x(x+1)}
is there any way to prove that the sequence is decreasing the way i started?
murshid_islam said:
is it correct?
Wait, wait, wait, my proof is erroneous. y = \ln\left(1+\frac{1}{x}\right) then y&#039; = \frac{-1}{x(x+1)}
You are correct. I'll edit my proof right now.
is there any way to prove the sequesnce is decreasing by one of the following:
a_{k+1}-a_k &lt; 0
\frac{a_{k+1}}{a_k} &lt; 1
f&#039;(k) &lt; 0
