Time invarient pdf but nonstationary process
  • Thread starter Thread starter shifo79
    Pdf Process Time
A solution to the general stochastic differential equation (SDE) can yield a time-independent probability density function (pdf) while maintaining a nonstationary stochastic process. It is possible to have a constant distribution function with a correlation function that depends on both time variables, indicating nonstationarity. An example provided is a Gaussian process with a mean of zero and standard deviation of one, where the correlation function is defined as f(s,t) = 1/(1+|s²-t²|). The discussion raises questions about how to compute this correlation and the apparent contradiction of having a time-independent pdf alongside a time-dependent correlation function. Understanding these concepts is crucial for exploring the dynamics of stochastic processes.
shifo79
I am wondering if there exist some solution to the general stochastic differential equation (SDE) such that I get a time independent pdf(x) while the stochastic process Xt is nonstationary.. I really need some help with that..
I am not sure what you mean by a general stochastic diff. eq. However, it is possible to have a stochastic process with a constant distribution function, but where the correlation function is dependent on both values of the independent (time) variable, and not just the difference - therefore not stationary.
OK, forget about the SDE .. can u give me example of a stochastic process such that the pdf (dosen't depend on time == > dp/dt=0) but the correlation has a time variable (nonstationary)? this will helpso much..
Gaussian process (mean=0, s.d=1) with a correl. dep. on both variables. For example f(s,t)=1/(1+|s2-t2|).
what's f(s,t)..
can u please tell me how to compute this correlation? if the pdf has not time in it, how come time appears in the correlation function?
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
