Can someone recommend a good computer program?
  • Thread starter Thread starter Fredrik
    Computer Program
A user is seeking a computer program capable of performing symbolic algebraic calculations, specifically for multiplying complex matrices. They provide an example involving an SU(2) matrix and a summation with Pauli spin matrices, expressing a desire for software that simplifies such calculations. The user mentions a lack of interest in performing the calculations manually and is looking for recommendations. Maxima is suggested as a free software option for these types of algebraic tasks. The discussion emphasizes the need for accessible tools for symbolic computation.
Fredrik
Staff Emeritus
Insights Author
I'm looking for a computer program that can do symbolical (i.e. not numerical) algebraic calculations. It doesn't have to do anything absurdly complicated, but it has to be able to multiply complex matrices. For example if I know that an arbitrary SU(2) matrix \lambda can be expressed as
\lambda=\begin{pmatrix}a& b\\ -b^*& a^*\end{pmatrix}
then what is
\sum_{i=1}^3 x^i \lambda\sigma_i\lambda^\dagger
where the \sigma_i are the Pauli spin matrices? I came across this expression the other day, and I decided that I don't care enough about the result to do the calculation explicitly. :smile: I also thought that there must be some kind of software that makes this sort of thing easy.
So...can someone recommend a program that can do this sort of thing?
Mathematics news on Phys.org
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
