Uptime of Successful Event in 60s Experiments
  • Thread starter Thread starter Nasta
The discussion centers on modeling the uptime of a successful event in a series of experiments conducted over 60 seconds, where each event lasts 10 seconds with a 10% probability of success every 3 seconds. Participants explore various methods to calculate the expected uptime, including Bernoulli trials and probability calculations for collisions and renewals of success. One participant calculates a 29% uptime based on the probability of at least one successful event occurring within the timeframe, while questioning the theoretical basis for this approach. Concerns are raised about implicit assumptions regarding the distribution of the experiment and how to analyze empirical data once available. The conversation highlights the complexity of accurately modeling the uptime given the nature of the experimental setup.
Nasta
I have the following problem:
A trial of an experiment can yield a "successful" event which lasts for 10 seconds with probability 0.1. The experiment is repeated every 3 seconds. If it yields a successful event while the 10 seconds of a previous one still haven't expired, it will just renew the timer to 10 again. The question is, how should the uptime of the successful event over the course of 60 seconds be modeled?
I was thinking the following:
There are 20 experiments over the course of 60 seconds, and since this is a Bernoulli experiment in a way, the mean number of successes will be n*p, i.e. 2 and their uptime is 10 each, thus 20/60 = 1/3 of the time.
But then again, I am not sure if this takes into consideration the possibility that a successful event will renew the timer of a successful event that happened less than 10 seconds before.
Any ideas how exactly to model the uptime of the successful event from this experiment?
What do you need to find, the mean or a distribution model? Do you need a proof or just a number?
A very easy way would be to test it a million times, giving a distribution but no proof. Another easy way would be to find the average for the first 10 seconds and then multiply out the expected value for the others as 0.1(0.1 * 3 + 0.9 * 0.1 * 6 + 0.9^2 * 0.1 * 9 + 0.9^3 * 10), giving a proof of only the mean.
This is a nice problem. I have not solved it out, but can see your solution being wrong.
Consider the first experiment is a success then we start to count. The probability of discontinuity in the first 10 second is (9/10)^3 = 0.729. And the probability of discontinuity until second 60 will be higher than that, if not very much.
I calculate the chance of a collision in 60 seconds at 98.784%. I think the chance of collision in the first 10 seconds is 5.23%.
Turned out it is simper than I thought actually...I just had to find the probability of at least one successful event in the 10 seconds, like you said in the 2nd post, and that is 1-P(No successful event) = 1-(1-0.1)^(3+1/3) (since there are 3+1/3 trials in 10 seconds), which is around 0.29 and the uptime is thus roughly 29%. What bothers me in this way of "solving" the problem is, firstly, is there any theoretical basis for looking at at the probability of at least one successful event (and thus the mean) for exactly the length of a success? And the other thing is - have we made an implicit assumption in this way about the distribution of the experiment? I still don't have the possibility to test the empirical distribution of that experiment (i.e. it is an object that does this certain effect, but i am still not in the possession of it), but when i get my hands on it, how can i go around finding out the theoretical distribution? i.e. if i know for sure that the parameter of the distribution is 0.1 and have an empirical uptime of 30% or 40% or 50% how shall i proceed?
If you ran the experiment for 9 seconds before starting the timer and counted results that ran over the period you could use the formula I gave above, which would yield 29.53% uptime. Not running the experiment before the 60 seconds increases this, and not measuring the leftover runtime decreases it, so your figure is believable.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
