Representations of SU(2) are equivalent to their duals
The discussion revolves around proving the equivalence of irreducible representations of SU(2) to their dual representations, specifically focusing on homogeneous polynomials in two complex variables of degree 2j. The participants clarify that the space of such polynomials is an n+1 dimensional vector space, with a corresponding dual basis formed by 1-forms. The action of SU(2) on these polynomials is described, emphasizing the transformation of variables via matrix multiplication. Questions arise regarding efficient methods to handle polynomial transformations and demonstrating the one-to-one and onto nature of the action. The conversation highlights the need for a clearer mapping between the polynomial space and its dual to establish the desired equivalence.
arg
Hi.
I am having trouble proving that the irreducible representations of SU(2) are equivalent to their dual representations.
The reps I am looking at are the spaces of homogenous polynomials in 2 complex variables of degree 2j (where j is 0, 1/2, 1,...). If f is such a polynomial the action of an element g of SU(2) is to take f to
f(g^{-1} \left(<br /> \begin{array}{cc}<br /> x\\<br /> y \end{array}<br /> \right) )
What is the dual space of this set of polynomials and how do you combine an element of the dual space with the original space to get a number?
I can find no proof of the equivalence of a representation with its dual. If anyone has any insight please let me know. Please let me know if I need to clarify anything.
Thanks very much.
Mathematics news on Phys.org
That set of polynomials is _just_ a vector space. So write down the obvious basis, hence te dual basis, and now what is the action of SU(2)?
Hi Matt. Thanks for your quick reply.
So if the degree of the homogenous polynomials is n the basis is:
x^n, x^{n-1}y, x^{n-2}y^2, ... , xy^{n-1}, y^n so it is an n+1 dimensional vector space.
I guess the dual basis are the n+1 1-forms, the jth of which eats x^ky^{n-k} and spits out 1 if k=j and 0 otherwise.
The way I understand the action of an element g of SU(2) on the polynomial f(x,y) is to take the matrix g^{-1} and multiply it on the right by the column vector \left(\begin{array}(x\\y\end{array} \right). Then you get another column vector. Take the top element of this vector and plug it into the x-slot in f(x,y) and plug the bottom element of the vector into the y-slot. Now if you multiply everything out and regroup the terms you have another homogenous polynomial of degree n.
At this point I have several questions. Is there a way to work with these new polynomials without multiplying everything out by hand? How does one show that the action of g on this space of polynomials is 1-1 and onto? How can I come up with a good map from this space of polynomials to the dual space?
Thanks a lot.
The double dual of V is what you started with...
I don't follow you. Can you be a bit more specific? Do you mean that the basis I listed is not the basis of the homogeneous polynomials of two complex variables? Thanks.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
