Physics Lab - Projectile Motion - Deriving a Position Vector
The discussion revolves around a physics lab focused on projectile motion, specifically deriving the position vector of water launched from a drinking fountain. Participants are tasked with determining various vectors, including position, velocity, and acceleration, while considering the effects of gravity and the initial launch conditions.
  • Participants explore the components of the position vector and question how to derive other vectors from it. There is uncertainty about the definitions of velocity and acceleration vectors, as well as how to calculate the initial launch angle and minimum speed of the water.
The discussion includes various attempts to clarify the problem setup and the relationships between different vectors. Some participants have provided insights into measuring the trajectory and the effects of gravity, while others express confusion about the calculations and assumptions required.
Participants are limited to using a ruler for measurements, and there is a mention of a specific time measurement obtained with a cell phone timer. The original poster indicates that the problem's complexity is heightened by the need to derive multiple vectors from limited data.
Ahwleung
Okay, this lab has had me stumped for the last few hours. This is our first lab for AP Physics BC.
Problem: Determine the position vector that describes the locatino of the water that is launched by a drinking fountain. Your position vector needs to be in unit vector format (i, j, k) & will include the variable t (t=0 when the water droplet is at the spout). Also determine the velocity vector, the acceleration vector, the initial velocity, the initial launch angle, and the minimum speed of the water (which is 0 at the top because the water goes up, then down)
My thoughts: It's just two dimensions so no k variable and we were only allowed to use a ruler, no stopwatches or anything else so I assume you solve for t in the equations later on. Just in case, we used cell phone timers and got t = 2.1 seconds. The Origin (0,0) is at the left edge of the drinking fountain.
The measurements are kind of complicated, so I'll just put them into a paint file.
We did a problem involving vectors in which we used the equation (parenthesis = subscript)
r(f) = r(i) + v(i)*t + .5a(t^2)
So I assume you must find out r(i), v(i), change in time, and "a" (acceleration)
This is the part that has me stumped. At first, the answer seems kind of obvious. Looking at the green vector, the component parts are clear (change in x = -.23 m, change in y = -.05 m) and thus the position vector is -.23i -.05j. But from there, how would one go about finding all the other answers? Heres my thoughts on the other vectors.
Velocity Vector: I'm not sure what they are asking for. Are they asking for the velocity of the water in a vector format, or the velocity of the position vector?
Acceleration Vector: Is it possible to derive a vector? Could I just derive the position vector to find velocity and derive again to find acceleration?
Initial velocity: Apparently I have to resort to the old kinematics equation to find initial velocity.
Initial Launch Angle: Now this part has me worried. I don't think you can solve for it in an equation; were we supposed to measure how HIGH the water went and do a simple tangent equation?
The minimum speed: easy, it's 0 because the velocity goes from positive to negative and thus must hit 0 at some point (like throwing a ball into the air and catching it). Or is it not that easy because the water is moving in the x direction?
Sorry for this outrageously long post. I've been staring at this lab for hours and I can't seem to make any headway into it. Thanks ahead of time for your consideration.
As a side note/funny little story, our physics teacher claimed that he DREAMED of this lab; he wanted to show us that with a ruler and a little brainwork you can solve for anything.
He also said that our final would be to find the air pressure of the room with only a ruler, a compass, and a piece of scotch tape.
I've found that the acceleration is -9.8j because its gravity...
I think one should strart by trying to discover whether the stream is following a parabolic trajectory. This could be investigated by marking the position of the stream on a plastic sheet (transparency) held next to the stream. Mark its position by holding the sheet between you and the stream. I think what he wants you to do is describe the position coordinates of a droplet of water as is traveling along the stream (as a function of time). It is probably best to locate the origin at the exit point of the water (by viewing the stream from the other side than that in your drawing it flows left to right). If you are just suppose to use a ruler this can still be achieved but with more effort. In such case you need to measure both the x- and y-coordinates of the stream. Map a line at constant intervals in the basin along the x-axis and then measure the y-coords of the stream up from these points.
  • · Replies 30 ·
  • · Replies 39 ·
