Sigma Notation Help: 5+10+17+26
  • Thread starter Thread starter 123mathguy
    Sigma
The discussion focuses on expressing the sequence 5, 10, 17, 26 in sigma notation and analyzing its pattern. Participants explore various forms of sigma notation, including set notation and summation formulas, while noting the constant second differences that indicate a quadratic relationship. The sequence's first differences (5, 7, 9) and second differences (2, 2) lead to the conclusion that the nth term can be represented as a quadratic function. A linear system is derived from substituting points into the quadratic equation, which helps in determining the coefficients. The conversation emphasizes that there are multiple valid approaches to represent the sequence mathematically.
123mathguy
can some one show me how to write
5+10+17+26 in sigma notation
Mathematics news on Phys.org
do you notice anything about those numbers? From 5 how do you get to 10? from 10 how to get to 17? from 17 how to get to 26? etc
One way would be
S=\{5,10,17,26\}
\sum_{x\in S}x
Another:
s_1=5,s_2=10,s_3=17,s_4=26
\sum_{k=1}^4s_k
Another:
\sum_{k=1}^4k^2+2k+2
I can get the nth term that is
Tn=2+\sum_{k=1}^n2k+1
but I don't know how to get from the Tn to Sn.
How CRGreatHouse see that or how did he trasform from the nth term to the Sn term?
\S_n=sum_{b=1}^nT_b
where
\T_b=2+sum_{k=1}^b2k+1
this is what I can do at most!
There is no 'unique' or 'canonical' way to do it. There are many ways. Yours (it appears to me) is fine.
I noticed that the second differences were constant, which means that a quadratic can be uniquely fitted to it. The sequence is 5, 10, 17, 26; the first differences are 5, 7, 9; the second differences are 2, 2. I then solved the system a+b+c=5, 4a+2b+c=10, 9a+3b+c=17. (I could have used 16a+4b+c=26 but didn't need it.)
I try some examples and see that when there's a difference of 2, then we can somewhat say that the nth term contains k^2,
well, but i fail to guess how you come out with the linear system, a+b+c=5, 4a+2b+c=10, 9a+3b+c=17.
Sorry, I have been trying hard to think about it.
I'm looking for a solution to y = ax^2 + bx + c with (x, y) = (1, 5), (2, 10), and (3, 17). Substitute and you get the linear system above.
In general, you can use "Newton's Difference Formula":
If you have a sequence {an} so that a0= a, the first difference, a1- a0, is b, the "second difference" (subtract the first two first differences) is c, etc. then an= a+ bn+ (c/2)n(n-1)+ ... It looks a lot like a Taylor's series formula but you use n(n-1)(n-2)...(n-k) instead of xk.
