Is this an inner product on R3?
  • Thread starter Thread starter jacko_20
The proposed definition of the inner product on R3, <u,v>=u2v2+u3v3, fails to satisfy the inner product axioms due to the exclusion of the first components u1 and v1. While the axioms of symmetry, linearity, and non-negativity appear to be satisfied, the fourth axiom is violated because it allows for non-zero vectors where u1 is arbitrary, leading to a contradiction. Specifically, if <u,u>=0 implies u2=0 and u3=0, then u1 can still be non-zero, which violates the requirement that the inner product of a non-zero vector must be positive. Therefore, this definition cannot be considered a valid inner product on R3. The discussion highlights the importance of including all vector components in defining inner products.
jacko_20
We define: <u,v>=u2v2+u3v3
For vectors u=(u1,u2,u3) and v=(v1,v2,v3) in R3.
Explain the reasons why this is not an inner product on R3.
I have completed the 4 axioms as below:
1. <u,v>= u2v3 + u3v3
=v2u2 + v3u3
=<v,u>
2.<cu,v> = cu1v2+cu2v2
= c(u2v2+u3v3)
= c<u,v>
3.<u,v+w>=u2(v2+w2)+u3(v3,w3)
= u2v2+u2w2+u3v3+u3w3
= <u,v>+<u,w>
4.a) <u,u>=u22 + u32
greater than or equal to zero as u2^2 greater than or equal to zero and u3^2 is greater than or equal to zero
b) <u,u>=0 then u2=0 and u3=0.
Somehow I've wrongly proved all the axioms :S I am assuming this does not define an inner product as it does not include u1 and v1 in the inner product, therefore cannot be an inner product in R^3. I would greatly appreciate anyone looking over my work to help me! Thanks
Mathematics news on Phys.org
your last step is wrong
proving u2 = u3=0 leaves u1 arbitrary and so the vector u = (u1, 0, 0) which is non-zero violates axiom 4 b).
Thanks mjsd! So it is correct that none of the other axioms apart from 4.b) depend on u1 or v1?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
