What Does 'D' Stand for in ODEs?
  • Thread starter Thread starter brunie
brunie
Hi,
I was doing a few homework questions and I came about a few ODEs of this form.
For example,
(XD^3 + 4D^2)y = 8e^x
Im not sure what the D stands for, is it a constant, is it a derivative of y (ie. y'''), etc. ??
In the same section of problems there were questions that I solved using undetermined coefficient method by finding both the homogenous and particular solutions.
Any help would be appreicated.
AB
"D" represents the differential operator. D^2 is the second derivative and D^3 is the third derivative. Is the X in "XD^3" supposed to be x?
If you let u= D^2 y (i.e. u= y") then that equation reduces to the linear first order equation xu'+ 4y= 8e^x. You can solve that by finding the integrating factor and then integrate twice more to find y.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
