How Do You Calculate Total Seats in a Concert Hall with Increasing Row Sizes?
  • Thread starter Thread starter Blueshy
    Increasing Row
To calculate the total number of seats in a concert hall with 150 rows, where each row increases by 10% from the previous one starting with 100 seats, one can use the formula for a geometric series. The number of seats in the nth row can be expressed as 100 * (1.1)^n, with n starting at 0 for the first row. The total seats can be found by summing this series for n from 0 to 149. The formula for the sum of a geometric series will provide the total number of seats in the concert hall. Understanding this concept is essential for solving similar problems involving exponential growth in seating arrangements.
Blueshy
Increasing Row Size...
There are 150 rows at a concert hall. Each row you move back there is an increase of 10% in the number of seats. The first row has 100 seats. How many seats are there in the concert hall?
I don't know the equation to represent this change.
Obviously I could go through and do each rows amount of seats, but I'd like to know the equation that will solve this. Is it n(n+1)/2?
It's called a geometric series. The number of seats in the nth row is 100*(1.1)^n (where n=0 is the first row). Now find a reference and look for 'geometric series'.
Notice that the number of seats in each successive row increases by a constant proportion, that is, each row has 1.10 times as many seats as the preceding row. What kind of a sequence is this?
If you have to add a finite number of terms of a sequence of this type, what formula do you use?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
