How does magnetism arise in permanent magnets?
Magnetism in permanent magnets arises from the alignment of individual electron magnetic moments within the material. Unlike moving charges that create magnetic fields through special relativity, permanent magnets generate their fields from stationary electrons in specific configurations. The magnetic properties depend on the arrangement of these moments, which can be grouped into domains that align in the same direction. When these domains align, they produce a significant overall magnetic field. Understanding this alignment is crucial for grasping the nature of magnetism in solid materials.
FredMadison
Hi everyone!
As I understand it, magnetism can be explained by special relativity when charges are moving - length contraction in different frames of reference leads to coulomb forces between the charges in these frames.
But how does magnetism in a permanent magnet arise? Are there currents flowing in the metal?
In a permanent magnet the field comes from the individual electrons moving around the atoms. Materials are magnetic when the electron configuration is such that these individual magnetic moments add up rather than cancel out.
I remember it deals with the minute fields (called domains) all lining up in the same direction to compound and create a big magnetic field.
Thanks
Yeah, that makes sense. Thanks a lot!
The most important thing I've learned so far in university physics is to think a few steps further. Sometimes you need a little help in doing so. This forum is great
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
