Solve Probability on HP50g: 3 Defectives in 7 Batteries Lot
  • Thread starter Thread starter silverbabe
    Statistical
To solve the probability of finding exactly 3 defective batteries in a sample of 7 from a lot of 80 batteries containing 13 defectives, the binomial distribution is applicable. The formula P(X=Y) with parameters (n, p, x) is essential, where n is the number of trials, p is the probability of success, and x is the number of successes. Understanding the binomial distribution allows for the calculation of probabilities based on the given parameters. The discussion emphasizes the importance of determining the correct strategy and formula before using the HP50g calculator for computations. Mastery of these concepts is crucial for accurate probability calculations.
silverbabe
how do I use the 50g to solve this one ?
in a 80 battery lot there are 13 defectives; then, if it is taken a sample of 7 batteries. Which is the probability to find exactly 3 defectives batteries?
Mathematics news on Phys.org
You don't use a calculator to solve a problem. You use a calculator to do the calculations after you have determined a strategy. What do you know about the "binomial distribution"?
...a strategy ?
You can use calculators to evaluate formulas, some even have formulas built in, by YOU have to know which formula to use! Again, what do you know about the "binomial distribution"?
I only know this one P(X=Y) (n,p,x)
Good, do you know what that means?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
