What Do Limiting Probabilities Signify in a Bose-Einstein Urn Model?
In a Bose-Einstein urn model with M molecules distributed between two urns, the process of moving molecules between urns is described as a time-reversible Markov process. The limiting probabilities, such as π_i, indicate the long-term distribution of particles, converging to a Binomial distribution where each particle has an equal probability of 1/2 of being in either urn. Specifically, π_0 represents the probability of one urn being empty, while π_i gives the likelihood of having i particles in one urn. This convergence occurs regardless of the initial distribution of particles, illustrating the system's tendency toward equilibrium. Ultimately, the limiting probabilities signify a stable distribution of distinguishable particles across the urns over time.
tronter
Suppose that M molecules are distributed among two urns; and at each time point one of the molecules it chosen at random, removed from its urn, and placed in the other one. So this is a time-reversible Markov process right?
So P_{i,i+1} = \frac{M-i}{M}. What do the limiting probabilities mean in words?
Like \pi_0 = \left[ 1 + \sum_{j=1}^{M} \frac{(M-j+1) \cdots (M-1)M}{j(j-1) \cdots 1} \right ]^{-1}
= \left [\sum_{j=0}^{M} \binom{M}{j} \right]^{-1} = \left(\frac{1}{2} \right)^{M}
and \pi_i = \binom{M}{i} \left(\frac{1}{2} \right)^{M}, \ i = 0,1, \ldots, M.
What do these really signify?
Source: Introduction to Probability Models by Sheldon Ross
Thanks
Limiting probability of a state-transition probability is a probability value that the state-transition probability converges to, as the number of steps approaches infinity.
See http://en.wikipedia.org/wiki/Markov_chain
I am not sure though, but the significance appears as-
The stated scheme in the long run is equivalent to distribute M distinguishable particles
in two urns where each particle has probability 1/2 to go into an urn. Pai(i) is the probability that one specified urn will contain i particles. That is, in the stated scheme, whatever be the initial distribution of particles in the urns, in a long run they will be distributed as in case of a Binomial distribution.
Usually a transition probability is expressed as p(i,j) where i and j are the two states. p(i,j) = Prob{X(n+1) = i given X(n) = j}.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
