Optoelectronics problem. Please assist
  • Thread starter Thread starter kuski
A phosphorus-doped silicon photoconductor exhibits a steady-state resistance of 550 Ω when exposed to far infrared radiation. Upon switching off the radiation, its resistance rises to 1 kΩ in 20 μs, prompting calculations for the intensity of the radiation and the carrier lifetime. The discussion highlights the relationship between resistance, carrier concentration, and mobility, emphasizing that the majority carriers are electrons due to phosphorus doping. There is also curiosity about the linearity of the I-V curve in the dark and under voltage bias, drawing comparisons to a diode's behavior. The conversation suggests estimating photon energy to calculate the incident radiant power per unit area on the sample.
kuski
A phosphorus (P) doped Si photoconductor is exposed to far IR radiation of unknown intensity. Its
steady state resistance is found to be 550 Ω. The far IR radiation is then
switched off, and the resistance of the photoconductor takes 20 μs to rise to 1
kΩ. Calculate the
i) intensity of the far IR radiation,
ii) carrier lifetime
Dimensions of photoconductor = (Lx × Ly × Lz) = 6 mm × 25 mm × 12 mm
(N.B. current is flowing in the x-direction, while the far IR radiation is incident
on the x-y plane of the photoconductor).
Wavelength of IR, λ = 12 μm
Electron mobility μ
e = 2500 cm2 V−1 s−1
Hole mobility μh = 1800 cm2 V−1 s−1
My attempt
Since the photoconductor was doped with P, the electron would be the majority carrier. And i equate
I = Area * (eVn + eVp)
= Area * (eVn)
And from this i would get
R= (length/area) 1/(eμn)
Since i have the resistance for steady state and during no illumination
I can apply the above formula with the resistance to find the n created by photons and the intrinsic n.
After which i have no idea what so ever on how to look for the intensity. Please help
Perhaps you could assume that every excited carrier corresponds to a photon passing through the sample. You should be able to estimate the photon energy quite precisely. Then calculate the radiant power per unit area incident on the sample.
thanks.. will definitely try that out. Another question that came to my mind is a photoconductor's conductivity changes according to the absorbed incident photons. So the i-v curve would be linear? in the dark? And what happens under voltage bias? I keep thinking of a diode's i-v curve.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
