Why do the edit post buttons sometimes turn into vote now buttons?
  • Thread starter Thread starter D H
The "edit post" feature sometimes displays a "vote now" button instead of the expected "save" option, leading to database error messages upon submission. This issue appears to escalate with multiple edits, as subsequent edits can turn other buttons like "go advanced" and "delete" into "vote now" as well. Users have noted that the problem may be linked to posts containing erroneous LaTeX, although this connection is not definitively established. Opening the edit page in a new tab seems to trigger the issue, while refreshing or canceling may restore normal functionality. Overall, the discussion highlights a frustrating glitch affecting post editing on the platform.
D H
Staff Emeritus
Insights Author
When I edit a post, the "save" button sometimes turns into "vote now". Clicking on this "vote now" button submits the changes but also gives a database error message. If I edit that same post a second time, the "go advanced" button also becomes "vote now" (I have two vote now buttons). On a third edit, the "delete" button also becomes "vote now". The problem seems to be associated with posts with erroneous LaTeX, but that might just be appearance.
vote now!
Hi D H! :smile:
I've only just noticed that …
I usually open the edit page in a new tab, but just now I opened one in the same tab, and got a "vote now" button just as you did.
I tried it on another thread, and found the same. But when I pressed cancel, and then pressed edit again, everything returned to normal. :biggrin:
EDIT: hmm … only got boring old save this time. :redface:
EDIT: and this time. :frown:
EDIT: oooh … I give up! :cry:
How bizarre! When I click the edit button on both of your posts, I get weird options; like vote now, two buttons that say cancel etc..
Homework Statement: Not applicable. I'm asking about a technical problem with the PhysicsForums software Relevant Equations: \left(-2+2 \,\mathrm{I}\right)^{\frac{1}{3}} \left(-2+2 \,\mathrm{I}\right)^{\frac{1}{3}} I posted the LaTeX code for an expression in the "relevant equations" and "attempt at a solution" boxes. When I'm in the "attempt at a solution" box and I click "Preview," I do not see a preview of the expression properly displayed, only the code. After I post this message...
