epkid08
- 264
- 1
Specific examples please
I think you misunderstand, I interpret the page to be saying that even if there are no massive objects to curve spacetime, at extremely tiny scales vacuum fluctuations will cause non-negligible curvature so it's unrealistic to just take for granted a flat background spacetime. So this is a matter of GR, not SR.atyy said:The page recommended by JesseM seems to say that there is a conflict between special relativity and quantum mechanics: "Even in presumably empty space, this "flatness" gets called into question by the uncertainty principle if you examine space at extremely tiny scales." I don't understand this, since I usually hear that it is GR, not special relativity that conflicts with quantum mechanics.
atyy said:... technical problem of general relativity’s non-renormalizability.
ehj said:What is renormalizability?
atyy said:The idea to take general relativity and "merge it with quantum mechanics following the conventional methods of quantum field theory, but circumventing the traditional difficulties by an intelligent retuning of the quantization method itself" that Rovelli mentioned but didn't give references to in his scholarpedia article for may be the "asymptotically safe" field theory of gravity.
http://arxiv.org/abs/hep-th/0511260
http://relativity.livingreviews.org/Articles/lrr-2006-5/index.html
From the above-mentioned article by Lauscher and Reuter: The conclusion is that it seems quite possible to construct a quantum field theory of the spacetime metric which is not only an effective, but rather a fundamental one and which is mathematically consistent and predictive on the smallest possible length scales even. If so, it is not necessary to leave the realm of quantum field theory in order to construct a satisfactory quantum gravity. This is at variance with the basic credo of string theory, for instance, which is also claimed to provide a consistent gravity theory.
exponent137 said:I try to understand, why the GR is background free, but I do not succeed.
It is posible visualy to describe? It goes without diffeomorphism?
Let us say that we have 3 dimensional space with c = oo. I imagine that we can put GR in this space. Only what we should do is to stretch and reduce some distances and some time differences?
I imagine special relativity (SR). Here we can have 3 dimensional space with c = oo and we put in it SR space. For observers with v <> 0 streching and reduction of some distances happens. What is new in GR?
aranoff said:When we get to the very small, geometry is not important.
This is one of the reasons quantum mechanics tends to deal with momentum rather than velocity. Momentum can be measured e.g. via collisions or via wavelength. But any attempt to calculate [itex]\delta x / \delta t[/itex] as [itex]\delta t \rightarrow 0[/itex] is doomed to failure, because as the uncertainty in x decreases, the uncertainty in momentum increases, and the "expected momentum" becomes infinite, yielding an "expected speed" of c, for any particle whose position is known precisely! This is the maths' way of saying you can't do this.Antenna Guy said:So long as forward difference is a mere approximation of a derivative, how can one determine anything when everything used to measure change approaches zero?
DrGreg said:This is one of the reasons quantum mechanics tends to deal with momentum rather than velocity.
