Why Do Bushing Current Transformer Costs Increase with Lower Turn Ratios?
The discussion centers on the unexpected increase in bushing current transformer (BCT) costs despite a reduction in the power transformer rating. It highlights that a lower turn ratio requires more turns to maintain accurate current output for existing instruments, which can lead to higher manufacturing costs. The user expresses confusion over why BCT costs did not decrease like other components. The necessity for additional turns to ensure proper functionality is a key factor driving the cost increase. Understanding this relationship between turn ratio and cost is essential for evaluating transformer pricing.
m.s.j
In an industrial project, the customer decided to change first order for new power transformer. According to new order, the rating power of transformer should be half. He enquired new detail cost table and transformer manufacturer submitted it. Future power transformer user cheeked that mentioned list; he noted all detail items cost decreased approximately except bushing current transformers costs. He can not understand the reason of this cost impact.
How can you explain the reason of BCT cost increasing due to its turn ratio decreasing?
Creative thinking is enjoyable,Then think about your surrounding things and other thought products. http://electrical-riddles.com
Wouldn't you need twice the number of turns for half the current from the new power transformer? If not your ct output would not be correct for the existing instruments.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
