How Can You Calculate the Emissivity of Argon for Heat Transfer Analysis?
Emissivity of argon is very low due to its nature as a rare gas, which does not emit significant radiation in the infrared range at ordinary temperatures. For calculating emissivity, resources such as academic papers and studies on heat transfer in gases can provide valuable insights. The discussion also suggests exploring heat conduction and convection in gases to understand their roles in heat transfer better. Graphing heat transfer against temperature may reveal how different factors influence thermal behavior in argon. Overall, understanding the emissivity of argon is crucial for accurate heat transfer analysis.
gemt
Hi,
Can anyone give me any information on where i could find information on the emissivity of a gas, particulally argon, or how i can calculate it? i am trying to create a graph of heat transfer against temperature and see which plays a larger role at particular temperatures when transfering heat through a gas.
Thanks
Gemma :-)
Science news on Phys.org
Curiously with Argon being a rare gas and the observation that oxygen nitrogen and the rare gases do not emit radiation in the IR range of the EMR at ordinary temperatures the answer is the emissivity is very very low.
http://dspace.mit.edu/handle/1721.1/11211
Are you more interested in heat conduction by gases? See
http://www.decompression.org/maiken/Why_Argon.htm
Also consider heat convection by gases.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
