Calculating Particle Decay in a Magnetic Field
mt948434
hello everybody I am new too these forums and am looking for a little help on a problem. I don't want anyone to give me the answer so i will just post the basic question and any help would be appreciated.
If an uncharged meson decays into two charged pions in the presence of a magnetic field. If the mass of a pion, magnitude of the magnetic field and the radius of the pions path are all known, I need to find the pions momenta and speed, as well as the mass of the meson.
thanks for any help!
1. There is a formula for the pion's momentum in terms of the radius and B.
2. Given the pion momentum, and knowing its mass, use the formula for the pion energy.
3. From p and E, you can find the pion velocity.
4. To get the meson's mass, you have to know the original angle between the two pions momenta. Then use M^2=(E_1+E_2)^2-({\vec p}_1+{\vec p}_2)^2.
thanks a lot for your help
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
