Ice vs. Dry Ice total BTU cooling to 25 degrees C
Regular ice provides a larger total BTU cooling effect compared to dry ice when both are used to reach a temperature of 25 degrees C. One pound of ice starting at -3 degrees C can absorb significant heat as it melts and warms up, while one pound of dry ice starting at -80 degrees C has a lower heat capacity as a gas. The heat of fusion and specific heat capacity are critical factors in determining the total energy absorbed. Although dry ice is colder initially, its efficiency diminishes due to the lower heat capacity of CO2 gas. Therefore, regular ice is more effective for cooling in this scenario.
bguthire
I wanted to ask which would provide the largest total BTU cooling regular ice from water or dry ice to reach a temperature of 25 degrees C?
1 lb of Ice would start at -3 degrees C to 25 degrees C at sea level = total BTU
1 lb of Dry ice would start at -80 degrees C to 25 degrees C at sea level = total BTU
You need the heat of fusion = the energy released when a mass of a solid melts
and the specific heat capacity = the energy released by deg rise in temperature once the substance has melted.
Although the CO2 is at a lower temperature the heat capacity of a gas is much lower than water.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
