Simple Hex Multiplication question from AES Algorithm
The discussion centers on the AES algorithm's multiplication by x and its inverse function, specifically in the context of binary polynomials. The user seeks clarification on how to derive the multiplicative inverse of a polynomial, given the example where {57} · {13} = {fe}. The solution involves using the extended Euclidean algorithm to compute the inverse polynomial a(x) such that a(x) · b(x) mod m(x) = 1, where m(x) is defined as x^8 + x^4 + x^3 + x + 1. This method allows for the calculation of the inverse, enabling the user to derive {57} from {fe} and {13}.
  • Understanding of AES algorithm and its operations
  • Familiarity with binary polynomials and polynomial arithmetic
  • Knowledge of the extended Euclidean algorithm
  • Basic concepts of modular arithmetic
  • Study the implementation of the extended Euclidean algorithm for polynomials
  • Learn about modular arithmetic in the context of finite fields
  • Explore the concept of multiplicative inverses in polynomial rings
  • Review the full AES specification in FIPS 197 for deeper insights
Cryptographers, software developers implementing AES encryption, and anyone interested in understanding polynomial arithmetic in cryptographic algorithms.
CyberStasi
I searched around a while on the site to see if I could find a thread that could answer this question and was unable to find one. If this has already been asked before, I apologize.
I'm having a problem with something in the AES crypto algorithm.
http://csrc.nist.gov/publications/fips/fips197/fips-197.pdf"
In Section 4.2.1 (page 11), they talk about Multiplication by X. I completely understand what they are doing and how. My problem is that they don't ever explain the inverse function of this. Clearly there must be a way to reverse the multiplication. In there example, {57} · {13} = {fe}. I understand how they come to that, but I don't understand how would would take the result of {fe} with the known value of {13} and be able to derive {57}.
Ive been trying to figure it out for hours. I'm sure its something simple that I'm missing, but for whatever reason it escapes me.
If you don't want to view the PDF, here is the information they provide.
4.2.1 Multiplication by x
Multiplying the binary polynomial defined in equation (3.1) with the polynomial x results in
b7x^8 + b6x^7 + b5x^6 + b4x^5 + b3x^4 + b2x^3 + b1x^2 + b0x^1 + 0. (4.4)
The result x · b(x) is obtained by reducing the above result modulo m(x), as defined in equation 4.1 [ m(x) = x^8 + x^4 + x^3 + x + 1 ]. If b7 = 0, the result is already in reduced form. If b7 = 1, the reduction is accomplished by subtracting (i.e., XORing) the polynomial m(x). It follows that multiplication by x (i.e., {00000010} or {02}) can be implemented at the byte level as a left shift and a subsequent conditional bitwise XOR with {1b}. This operation on bytes is denoted by xtime(). Multiplication by higher powers of x can be implemented by repeated application of xtime(). By adding intermediate results, multiplication by any constant can be implemented.
For example, {57} · {13} = {fe} because
{57} · {02} = xtime({57}) = {ae}
{57} · {04} = xtime({ae}) = {47}
{57} · {08} = xtime({47}) = {8e}
{57} · {10} = xtime({8e}) = {07},
thus,
{57} · {13} = {57} · ({01} XOR {02} XOR {10})
= {57} XOR {ae} XOR {07}
= {fe}.
Mathematics news on Phys.org
It says right above where your quote that:
For any non-zero binary polynomial b(x) of degree less than 8, the multiplicative
inverse of b(x), denoted b-1(x), can be found as follows: the extended Euclidean algorithm [7] is
used to compute polynomials a(x) and c(x) such that
b(x)a(x) + m(x)c(x) = 1. (4.2)
Hence, a(x) · b(x) mod m(x) = 1, which means
b-1 (x) = a(x) mod m(x) .
Unless you're asking about something else?
