Mathematica How Do You Substitute Variable Values in Mathematica?
  • Thread starter Thread starter Sosi
    Mathematica
The discussion revolves around using Mathematica to assign a variable to an output and substitute it in an expression. The user initially attempts to substitute a solved variable, X1, into another expression, Vp, but encounters issues with the output remaining unchanged. The solution involves using "ReplaceAll" instead of "Replace," as it applies a more effective algorithm for substitution. Additionally, it is highlighted that the output from the Solve function is a list containing a transformation rather than a direct value. By applying "ReplaceAll" with the first component of the list, the user successfully achieves the desired substitution in the expression.
Sosi
Hi!
I'm doing my first steps in Mathematica and I've wanted to do something simple like assigning a variable to the output and then use it. Something like this:
Code:
In:Vp = vprx == kprx2*X1;
In:dX1 = kp X0 + X1 (-cat kcatl - kgpx gpx - kprx2 prx2);
In:rX1 = Solve[dX1 == 0, X1];
Out:{{X1 -> (kp X0)/(catalase kcatl + gpx kgpx + kprx2 prx2)}}
then i want to Sbustitute X1 in the expression Vp, with the value of the output of rX1.I'm using the function Replace but this doesn't do what I want. The output is:
Code:
In:Replace[Vp, X1 -> rX1]
Out:vprx == kprx2 X1
when it should be
Code:
Out:vprx==(kprx2kp X0)/(catalase kcatl + gpx kgpx + kprx2 prx2)
Thanks a lot for all the help!
There are two problems, one is simple, one is more complicated.
First, use "ReplaceAll" instead of "Replace", it uses a deeper algorithm that will properly do what you want it to do.
Second, look at the result of "rX1". It is NOT just a number that can be plugged in. It is a list that has one component with a variable, "X1", being transformed to a larger expression.
Try using:
Code:
ReplaceAll[Vp, rX1[[1]] ]
This takes the first component of the rX1 list and uses it in the ReplaceAll function.
jpreed said:
Try using:
Code:
Awsome! It works just as I wanted! Thanks a lot!
9K
